G90 firmware upgrade failed. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-09-2012, 01:44 PM - Thread Starter
Dung Truong's Avatar
The PC side seemed to be OK, but the PC failed to establish the initial handshake communication with the PJ: Always in hour-glass waiting mode until the connection timed out after exceeded the maximum # of retires. I tried just about everything I could think of and nothings go:
> Custom made the 9-pin cable & verified all pin connections end-to-end.
(1-1, 2x3 cross, 5-5, 4x6 cross, 7x8 cross, 9-9.)
> Also tried the other cross cables configuration as documented, but still no go.
> Tired 3 PC's: 2 XP-laptops, 1 Win98 desktop with verified good COM ports.
> Tried all 3 different baud rates (properly set on both PJ & PC).
> Tried both PJ's Device Index 00 & 01.
> Tried both PJ's Standby & Power-on modes.
> Tried both PJ's RS232C & 422A 9-pin inputs, just in case.
> Reset the PJ to Factory default (Service, Factory & Initial data).
Did anyone found anything else that I haven't tried?
The last resort would be to buy a Dallas chip with the software already upgrade in it and hope that it would work, but I will loose the serial # and hours used of the lens (not a big deal, really).
Thanks much.
DT999
Dung Truong is offline
post #2 of 8 Old 07-09-2012, 03:01 PM
CIR-Engineering's Avatar
The FW is not on the Dallas chip so getting a new Dallas won't update the FW.
I have had issues with updating the FW before. You can use a regular null modem cable, you don't need to make the custom one. Use RS-232 and a low baud rate as you have tried.
I once had a G90 that would not take the FW update. I finally got it to work by taking the YA board out of the G90 in which it was installed and put it in another G90. After this the FW update was successful. I still don't know why that worked.
craigr
Precision Video Calibration Craig Rounds
JETI Specbos 1211 Spectroradiometer
Klein K10-A Laboratory Grade Colorimeter
Murideo Fresco Six-G & Six-A HDMI 2.x Multimedia Generator / Analyzer
LightSpace XPS Pro & ChromaPure Pro Color Calibration Software
www.CIR-Engineering.com - craigr@cir-engineering.com
CIR-Engineering is offline
post #3 of 8 Old 07-09-2012, 04:37 PM - Thread Starter
Hi Graig,
I did try a regular null modem cable and it didn't work.
If the YA board was where the FW was kept, I hoped that some member with a G90 who lives nearby Orange County, CA may be be willing to host this YA board FW upgrade. I lived in Lake Forest, near El Toro/Laguna area. Will any member around here or in LA/SD areas be willing to do me this favor, or for a fee if needed to be? Even though I can live and get by with the original firmware release, some of the software bugs were quite a bit annoying without the fixes.
If no one felt comfortable in doing this, Craigr, will you be willing to do the upgrade for me if I send you the YA board, for a fee too, of course? You can PM me about this.
Thank you for your super quick reply.
Dung Truong
post #4 of 8 Old 07-09-2012, 06:42 PM - Thread Starter
I meant, sending me a private email, not a PM, sorry.
Dung Truong
post #5 of 8 Old 07-10-2012, 01:40 AM - Thread Starter
I guessed that I confused between PM which stood for Private msg but it also can stand for Public msg!
post #6 of 8 Old 07-10-2012, 07:37 AM
lewis's Avatar
I've also heard that communication between newer computers/OS's can be a problem. Guess its the generation gap. If you have or can get hold of an old laptop running a contemporary operating system (Windows 2000, XP etc) I would try that first before risking damage or loss of a valuable, functioning YA board.
lewis is offline
post #7 of 8 Old 07-10-2012, 08:24 AM
Dung Truong
Feel free to shoot me an email regarding this. My email is in the signature of all my posts.
Good luck!
craigr
post #8 of 8 Old 09-11-2012, 07:45 PM - Thread Starter
It turned out that my G90 was one of the earlier production unit and the firmware upgrade failed may be because of this. Craig put the YA board in his PJ and the upgrade went thru. I am now on the new firmware! Thanks Graig.
Reply CRT Projectors
