Screen size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-25-2012, 05:28 PM - Thread Starter
ilpostini2's Avatar
Quoted: 50 Post(s)
Testing a 6pg xtra that has like new tubes in it with a Moome unit. I have CIH screen that measures 120" wide and has a gain of 1.5 in a light controlled dedicated room.
Will this projector be able to fill this screen with good results?
ilpostini2 is offline
post #2 of 2 Old 07-30-2012, 12:50 PM
Vic C's Avatar
120" Wide screens are usually not recomended for CRT...The projector may fill the screen but most likely it will be dim.
You will be driving the projector hard and the new tubes will be old tubes really fast.
92" to 100" (diagnal) screens are the norm for CRT projectors especially 7" Models
Vic C is offline
Reply CRT Projectors
