barco data 500 help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-30-2012, 07:33 PM - Thread Starter
molardrew's Avatar
I have recently acquired a CRT projector and don't really know what I am doing. I connected my laptop to the projector via VGA and put my computer on the projector mode but nothing will show. I am thinking that I need to change the input on the projector but i don't have a remote control for it so I wouldn't know how to change it.
Any help would be great!
Drew
molardrew is offline
post #2 of 4 Old 08-31-2012, 07:57 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
You can't do anything without the remote, sorry! I have some available, or they do show up on eBay. Keep in mind that this is a really old projector. Check the tube condition before you spend any money on it, Pull the lenses and look at the tube condition:
http://curtpalme.com/TubeCondition_RatingChart.shtm
Any tube less than a 5 makes the set not worth spending any money on IMHO.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 4 Old 09-10-2012, 04:10 AM
Ile
Ile's Avatar
Before you get IR remote, you can use projectors internal back lit remote.
It should flip out from back panel. Internal remote.jpg 41k .jpg file
Name:	Internal remote.jpg
Ile is offline
post #4 of 4 Old 09-10-2012, 06:57 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
The 500 did not come with an internal keypad.
Reply CRT Projectors
