3 Free Sony CRTs, 2 X 1252, and 1 1272 / none of which are up and running right now - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-31-2012, 08:36 PM - Thread Starter
XylerB's Avatar
I have been out of the CRT game for several years now and these things just take up way too much space. If anyone wants to pickup everything I have, they can have it all for free. I'm located in Central IL. If I remember correctly, my 1252 tubes were atleast 8/10.... I had one decent running box, the others were used for parts. If I don't hear anything definitive about someone being interested in the next day or 2. I will probably just take them to a recycle place.
XylerB is offline
post #2 of 6 Old 09-01-2012, 08:07 AM
Ray133's Avatar
Why can't you be near Toronto. I would gladly give your pjs a good home
Ray133 is offline
post #3 of 6 Old 09-01-2012, 01:03 PM
zigger21's Avatar
I have a Sony CRT Big screen its a WS65-500 and I was wondering if these CRT's will work in this TV I dont have any problems with it and its been running hard for the past 10 years and I dont know how long they last but if you have a Red, Green and Blue CRTbulbs that would work in this 65WS500..
zigger21 is offline
post #4 of 6 Old 09-01-2012, 11:24 PM - Thread Starter
XylerB's Avatar
Honestly have no idea, if you can do a little research let me know.
XylerB is offline
post #5 of 6 Old 09-02-2012, 08:00 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
No they won't work.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #6 of 6 Old 09-05-2012, 10:03 AM
draganm's Avatar
Quoted: 21 Post(s)
wow, has it come to this? Over the last 10 years people would post countless times asking if RPTV tubes would fit into their CRT projector, desperate to keep it going without paying the $500. per tube cost for a CRT PJ.
Now it's the other way around, LOL.
find out what tubes you have, model number , etc., then do a search on e-bay and set up the search so that it automatically e-mail you every time a new listing comes up with those numbers. RPTV tubes are almost exclusively Electrostatic focus and they're very short, about 3 to 4 inches shorter than a CRT projector tube. This was done to accommodate the cabinet depth which they tried to make as shallow as possible
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
