nOOb to 3D (with NEC XG 1100LC) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-07-2012, 11:23 AM - Thread Starter
dna_alexoov's Avatar
Have been enjoying 720p and 1080i on my XG for years. But I'm now just starting to consider upgrading to 3D if it is easy (and cheap) enough. What is the minimum equipment I need to make it work other than a 3D bluray player and glasses? Being that the XG can do 120mzh at 720P, do I really need anything else?
dna_alexoov is offline
post #2 of 2 Old 09-07-2012, 02:16 PM
wildchild22's Avatar
Quoted: 29 Post(s)
You will not get it working well without a lumagen radiance + model. I tried and failed on my nec xg1352lc because of a blue band on top of the image aprox 3 inches in size. It cannot be corrected without altering timings and I couldnt afford a + lumagen so I quit while I was ahead. My regular lumagen radiance xd without the plus couldnt fix it.
wildchild22 is offline
Reply CRT Projectors
