PS3 and Barco Data 808 - What else do I need? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-19-2012, 12:48 PM - Thread Starter
Sturestig's Avatar
I'm considering buying a Barco Data 808.
What do I need to connect it to a PS3 and play bluerays and games? Of course I'd like to connect other HDMI-inputs as well, but the PS3 is crucial.
I've heard about HD Fury (different versions) but also Moome. What should I go for? Do I need Gamma correction as well?
/Jan
Sturestig is offline
post #2 of 3 Old 09-19-2012, 09:57 PM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
The Moome box has better RGB processing and gamma correction. Given that it's a Data 808, it needs negative sync, which can be changed on the Moome with internal jumpers. I'd get the Moome.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 3 Old 09-19-2012, 11:39 PM - Thread Starter
Sturestig's Avatar
OK. That sounds good.
Would it even work with my old Barco Data 600 until I get the 808? I've only used 4 connectors on when it's connected to the iScan Pro. Does the 808 have the same connectors?
Also - is this where I buy the Moome Box? http://www.moomecard.com/
Reply CRT Projectors
