Problem with HD on CRT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-06-2012, 01:53 AM - Thread Starter
superslav's Avatar
Having trouble with my Sony eh36m31 displaying HD. i connected my original xbox into the HD compodent ports in the back, the TV outputs 1080i and it detects the signal but its not outputting colors properly. The quality is perfect other than that
I put true crime streets of la in the TV in the menu says the TV switched to 720p/60hz, same thing happens. I tried this on my other sony trinitron and the same thing happends. Its not the xbox or cords because it works on my lcd.
superslav is offline
post #2 of 3 Old 10-06-2012, 06:33 PM
draganm's Avatar
Quoted: 21 Post(s)
Originally Posted by superslav View Post
Having trouble with my Sony .......it detects the signal but its not outputting colors properly.
make sure you put the red wire on the red RCA jack, the green wire on the green jack, and the blue wire on the blue jack smile.gif
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #3 of 3 Old 10-06-2012, 07:15 PM - Thread Starter
superslav's Avatar
Reply CRT Projectors
