ECP 4001 Green wont project?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-05-2012, 06:48 PM - Thread Starter
Theodore7's Avatar
Hello, I recently got this projector and everything seems to be fine, all the colors work in the menues but when I hook it up to me computer the green tube does not project the image??? any help please! edit-4101
Theodore7 is offline
post #2 of 5 Old 11-06-2012, 07:11 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
Your RGB input board may be bad, but I'd suspect your input cable. REverse the green and red BNC cables and make sure your green cable works. I've got lots of RGB input cards if you need another one.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 5 Old 11-06-2012, 09:53 AM - Thread Starter
Theodore7's Avatar
I got it, the connection if the green bnc cord has a little play. That was it, took me hours to figure it out. But so worth it. Thank you Curt!
post #4 of 5 Old 11-07-2012, 05:49 PM - Thread Starter
Theodore7's Avatar
I've run into another problem.. The center of the green gun will no focus, The direct center will but I little bit up and it refuses, no matter what I do. Is this a resistor issue on the Focus board?
post #5 of 5 Old 11-08-2012, 07:54 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
No, it sounds like you most likely have fungus. There is one global focus control per tube. If the edges are in focus, the centre should be as well. Fungus however will make it look like it's a mile out:
http://curtpalme.com/Fungus_Removal1.shtm
Reply CRT Projectors
