Sony G70 Died (No Power) UPDATE: Found dead cap, need to identify - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-12-2012, 02:14 PM - Thread Starter
KwintSommer's Avatar
Last night my G70 made a loud bang and stopped projecting. It has no power as far as I can tell.
I checked the fuse with a multimeter. It's fine.
I pulled each of the four boards that seem related to power. No puffy/leaking capacitors, burns or any other obvious signs of damage.
For good measure I installed a new fuse and 120V cord today. Still no power.
UPDATE: Found a dead capacitor and bit of scorching on the FAB board.
It's inside of what Curt calls the Main Power Supply 1
On the attached picture you can see that C2102 popped, C2103 and R2101 appear to need replacement as well. Anyone have a schematic or other way of figuring out what their values are? It looks like an easy fix but the caps don't appear to be labelled. rolleyes.gif
I checked Curt's list of manuals, great stuff but nothing that would tell me what those caps are.
So sages of AVS, I beseech thee: name those caps.
KwintSommer is offline
post #2 of 4 Old 11-12-2012, 04:49 PM
draganm's Avatar
Quoted: 21 Post(s)
I had an FAB do the exact same thing. The cap isn't necessarily the cause of the problem, might just be a domino in the failure chain.
anyway, boards are cheap now, just replace it.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #3 of 4 Old 11-13-2012, 01:10 PM - Thread Starter
I contacted one guy at Curt's site that might have a set of G70 power boards. Any other places you would recommend?
post #4 of 4 Old 11-14-2012, 09:14 AM
draganm's Avatar
Quoted: 21 Post(s)
Well he will almost certainly have one but let me know if he doesn't . I can check my inventory, I parted out 3 G70's a while back
draganm is offline
Reply CRT Projectors
