blu ray player sync issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-15-2012, 11:05 AM - Thread Starter
rockapulco's Avatar
The set up is samsung blu ray Pb/Pr/Y outputs to component/rgb converter to Marquis 8500. This all worked just fine until I tried to use HDMI Blu Ray output to interface with a scaler I was trying to introduce. Having gone back to the non scaler setup, I seemed to have screwed up the blu ray player setup in that projector will no longer sync (vert). Don't think it is projector issue as other inputs (HTPC) work fine. Any idea which player setup item???
Thx&Regards
rockapulco is offline
post #2 of 2 Old 11-16-2012, 04:23 PM - Thread Starter
rockapulco's Avatar
Resolved it, player setup issue, should have remembered, age thing!!
Reply CRT Projectors
