Sony G70 Error 27 / 36 ZeropowerSRAM exchange ? Hard Reset Softly Reset or no Reset ? - AVS Forum | Home Theater Discussions And Reviews
Old 11-16-2012, 03:15 AM - Thread Starter
1Deflection's Avatar
My English is not good. Translator translates.
Hello, I have two SonyG70, one does not function.
The SonyG70 had first Error 27 and one more Error.
(Button of the cable cover is on top on it OK)
The G70 has got afterwards the old software with G2 setting.
The original software has no manual G2 setting.
The trader had by this contribution in the link the idea with the Zeropower-SRAM exchange and hard Reset:
http:// www.avsforum.com/t/1193903/sony-g70-error-code-23-24-29-36
I have bought this:
http:// Www.ebay.de/itm/1-St-Zeropower-SRAM-M48Z128Y-70PM1-/360423969391
Another German trader CRT said of the old SRAM, is not mainly guilty in the mistake code:confused:
Can the old ZeropowerSRAM release / indicate an Error?
Is one necessary with new ZeropowerSRAM, hard Reset?
Is hard Reset 10 seconds of Reset button on the board properly press
Before the turning on already press???
1.
I have inserted the new ZeroPowerRAM.
2.
I have pressed the Reset counter the board and have switched on the G70 (main switch)
= First Error88
= G70 switched off and anew Reset.
= The G70 has got high voltage and has remained switched on.
= The green tube has easily shone???
3.
The G70 has high voltage, however, no menu Picture and the green tube Shining on the whole surface???
= I have operated the brightness counter
4.
Topically I have Error36 only with operate of the On key.
= the G70 switches off itself after 1 second with Error36.
Is it to be tested sensibly the V-Board E-Board and Y board?
Is it able to do yours the old Error 27 now is only invisible because error 36 is quicker?
Can I damage functioning Boards?
Greetings
Sebastian from Dortmund
1Deflection is offline
