how do a make the picture better on a zenith 900 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-08-2012, 12:45 AM - Thread Starter
jamhdit's Avatar
ive heard os a thing called a scaler and dont know how it works or how it would hook up to my projector
i have a zenith 900 crt projector
all ihave for inputs are composite i think. s video and a 9 pin connector that says rbg under it,
never plugged anythin into rgb or s video.
would a scaler work if so whet model and how do i hook it up
thaks in advance john
jamhdit is offline
post #2 of 6 Old 12-08-2012, 08:54 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Read this first:
http://curtpalme.com/CRTPrimer.shtm
Then get this:
www.moomecard.com.
Feeding a 1080i HDMI signal is the best thing you can do for the PRO 900, it's too low an end of set to really benefit from the money you'd spend on a scaler.
Do you have the large setup remote, and do you know how to converge, because the PRO 900 is a pain to set up if you've never done it before.
I have one setup remote left if you need one, and if the tubes are in decent shape (check that before you spend anything on this set), it will throw a nice picture.
If you've had this since new with video only sent to the projector, then you've been stuck in 1st gear in a 5 speed. You'll love the upgrade HD will give you.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 6 Old 12-08-2012, 01:43 PM - Thread Starter
jamhdit's Avatar
ok i always think i have the 900 but i actually have a zenith 880 so it quite a bit different.
sorry
i read your crt thread great stuff there.
after reading it i think my problem is the lines of resolution. i can see them seperated.
and i only have three possible connectoins on the back
the best being a 9 pin connector that says rgb.
i have never hooked anything to it mostly because this 9 pin is hard to find.
and apon reading your link i think this is the one i need to hook up to.
so my new question is am i rite and do i need a line doubler or just better hdmi signal?
thank again john
jamhdit is offline
post #4 of 6 Old 12-08-2012, 02:12 PM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Then sadly there's no upgrades that can be done, sorry! Best you can do is get a PRO 900 that fits onto the same bracket and has the same throw distance, and THEN follow my previous advice. smile.gif
post #5 of 6 Old 12-08-2012, 02:40 PM - Thread Starter
jamhdit's Avatar
would using that 9 pin connector make the picture better?
do you have any 900 models?
jamhdit is offline
post #6 of 6 Old 12-09-2012, 07:26 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
No, because the projector can only scan to a 320 X 240 video signal, so the 9 pin connector is useless.
Yes I do have a couple of PRO 900s in stock, shoot me an email to curtpalme at shaw.ca
Reply CRT Projectors
