Sony CRT - 1271QM - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-19-2012, 09:56 AM - Thread Starter
poen's Avatar
Hello there,
I am wondering what the best resolutions are for the Sony CRT - 1271QM beamer, also are there any guides found somewhere how to best 'set-up' this beamer?
Thanks in advance!
poen is offline
post #2 of 2 Old 12-19-2012, 02:58 PM
draganm's Avatar
Quoted: 21 Post(s)
you can run 1080i or 720P by sending the set either RGBHV signal or component video if you have the optional IFB12 input card. Everything including manuals is here
http://www.curtpalme.com/Sony125x.shtm
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
