Electrohome ecp Green tube too bright, connection problem? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-19-2012, 01:12 PM - Thread Starter
Theodore7's Avatar
hello,
Ok, so when I plug my connections in the green tube does not show, so I wiggle the connection a little bit, give it a few twists and then If I get it in the right position the tube displays the image, but its so bright the whole picture looks green?? ugh! Any ideas? Thank you -Jacob
Theodore7 is offline
post #2 of 6 Old 12-20-2012, 07:11 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
We need more info. What input are you using, and what signal source are you feeding to the set? What model ECP is it?
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 6 Old 12-24-2012, 03:08 PM - Thread Starter
Theodore7's Avatar
ECP-4101 Im using a vga to rgbhv. Signal, I have been using various resolutions at 60hz
post #4 of 6 Old 12-24-2012, 08:00 PM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
What happens in test pattern mode? Is the green too bright then?
post #5 of 6 Old 12-24-2012, 08:10 PM - Thread Starter
Theodore7's Avatar
No, its fine. Looks good.
post #6 of 6 Old 12-25-2012, 05:52 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
Sounds like a bad video input board. I'm assuming your computer is outputting RGBHV and not component? You're describing exactly what happens when you feed a component signal to an RGBHV input.
I've got spare RGBHV cards at $10 each plus shipping.
Reply CRT Projectors
