Sony 7" CRT Help!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-11-2013, 02:08 PM - Thread Starter
AUrator's Avatar
Hi All. I am helping a neighbor set my old system in his basement. This thing is the 68 pound behemoth 1998 VPH-V20M. I cannot figure out how to invert the video signal....I have always had it mounted on the ceiling, upside down. My friend wants to put it on a cart and shoot to the wall, so it will sit right-side up. I have the manual and there is nothing indicating how to get the picture to shoot the way we need it. It does, however, show that the unit can, in fact, be positioned this way. Any help is appreciated. Thanks.
gsp
If you really love your country, you're gonna have to love moonshine
AUrator is offline
post #2 of 4 Old 01-12-2013, 04:46 PM
draganm's Avatar
Quoted: 21 Post(s)
It's called scan reversal, look in the manual for those words. You typically have to remove 6 plugs, flip them then plug them back in
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #3 of 4 Old 03-05-2013, 01:29 PM - Thread Starter
AUrator's Avatar
There is nothing in the manual mentioning scan reversal. I am stumped. Where are the "plugs" you are referring to located, usually? Thanks.
AUrator is offline
post #4 of 4 Old 03-06-2013, 02:29 PM
draganm's Avatar
Quoted: 21 Post(s)
Well the geniuses at Sony left it out of that manual, it just says "to be performed by a factory technician". Look at this manual for the 1031, it should be the same chassis, page 22 "polarity change"
http://www.curtpalme.com/docs/Sony1031_Service.pdf
draganm is offline
Reply CRT Projectors
