Color range setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-19-2013, 02:02 AM - Thread Starter
georg's Avatar
Quoted: 20 Post(s)
Setting up my Cine 8 with the hdfury3. Does anyone know whether I should set it up as 0-255 capable or just 15-235?
georg is offline
post #2 of 4 Old 01-19-2013, 10:23 AM
neonsky's Avatar
What are your sources? If its just a htpc you should leave it full rgb if its bluray it should be 16-235.
neonsky is offline
post #3 of 4 Old 01-19-2013, 05:12 PM - Thread Starter
georg's Avatar
Quoted: 20 Post(s)
It is almost entirely bd-iso's from the hdd with xbmc.
georg is offline
post #4 of 4 Old 01-19-2013, 10:33 PM
neonsky's Avatar
If you're not gaming I would just do 16-235 for the blurays then. Honestly even if you game you won't notice the lack of full rgb.
neonsky is offline
Reply CRT Projectors
