Marquee (older) input cards, - DVI and RGB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-26-2013, 10:46 AM - Thread Starter
Vadim's Avatar
I was doing some cleaning and found two older input cards that would fit any Marquee projector, - they are:
1. An RGB-input card
2. DVI – input card
- DVI input
- Great internal scalar based on Genesis chip. Any input can be up-scaled to any resolution including 1080P.
- Custom resolutions
- Full menu-driven video adjustments
- Serial port for computer control
I used to have Marquee 9500 Ultra and I used this card with it.
I no longer have my 9500, so if anyone wants them, - $100 for both.
Vadim is offline
Reply CRT Projectors
