Seleco 350 image upside down - please help!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-25-2013, 10:26 AM - Thread Starter
harryhajin's Avatar
Hello there,
I have recently acquired a second hand Seleco 350 CRT projector.
It was originally set to a ceiling front projection and I wish to use it as a desktop projector.
Now... I've entered installation mode and changed the installation type from 'Ceiling front'
to 'Desktop front' and saved it as such. When I choose this option the image stretches a
little but other than there is no change - the image is still upside down.
When I switch the projector on and off again it is still saved as 'desktop front' and says so on
the information screen.
Any help/advice for this would be much appreciated as the picture quality is great otherwise...
and my neck is really starting to hurt!!!
I'm quite new to this so am assuming I have missed something very simple.
Thank you!!!!
Dan
harryhajin is offline
post #2 of 3 Old 02-25-2013, 11:51 AM
draganm's Avatar
Quoted: 21 Post(s)
read the manual, there's plugs or hard switches that need to be inverted, page 55
http://www.curtpalme.com/docs/Seleco310_350_Install_User.pdf
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #3 of 3 Old 02-25-2013, 01:42 PM - Thread Starter
harryhajin's Avatar
Many thanks for that, all sorted now!!
Reply CRT Projectors
