AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   CRT Projectors (http://www.avsforum.com/forum/16-crt-projectors/)
-   -   marquee 9500 HDB (http://www.avsforum.com/forum/16-crt-projectors/1469938-marquee-9500-hdb.html)
hjhjr 04-25-2013 11:41 AM
I need to do the folded image modification on the HDB board from Tech Bulletin TB95-10. I found D57 can not find BAT81. Some one please help.
draganm 04-25-2013 12:52 PM
are you sure you know what your doing? BAT81 isn't a location on the board, D57 is a BAT81 diode.
http://www.futurlec.com/Diodes/BAT81pr.shtml
and it's only found on the 07P HDM manufactured over a 4 month period in 1995. Are you sure that's the actual board you have?
The DOM is on the front, white sticker next to the power chord.
hjhjr 04-25-2013 07:36 PM
I misread the tech bulletin. The way it was printed (replace diode D7, BAT81) I took it replace two diodes. I am a older electronic tech. guess my reading skills are slipping.
It is the 07P board.
draganm 04-26-2013 04:09 PM
ok, but it would have to be a very rare board to have been made over that 4 month period. The 07 HDM was made for 4+ years.
Is it really folding? if it's clipping a couple of inches off each side of the image then that's normal without a video scaler. Using a video processor and lengthening the porch sizes from Blue ray and DVD will display the entire image, otherwise you lose a little on the sides.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
