Curious of a material inside of a Cathode Ray Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-04-2013, 12:47 AM - Thread Starter
Flyingmartini's Avatar
So, I busted up a CRT monitor. A fairly large one,32 inch flat screen, and inside of the Cathode Ray Projector I found a strange smooth metal, that is magnetic. I was curious to what kind of material this may be. I can't seem to find anything online to tell me what it may be, but I feel like it might be important so I really would like to know.
It is very smooth, seems slate like, but it is magnetic. Maybe a compound of metals? Maybe not, I have no idea. Does anyone know what this might be?
Thank you very much!
Oh, and to make it more clear, it is a BLACK satin metal that is very smooth and shatters with a hammer pretty easy.
The main reason I'm curious is that I really like to hold on to solid elements (if it is an element and not a compound). So if this is an element I'd love to know.
Flyingmartini is offline
post #2 of 2 Old 06-04-2013, 01:28 PM
draganm's Avatar
Quoted: 21 Post(s)
more than likely the Cathode
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
