Sony e400 crt monitor problem, please help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-15-2013, 08:25 PM - Thread Starter
alexretro's Avatar
i noticed a pinkish colored box being displayed when no computer is plugged into the monitor. when i plug in a computer the windows 7 displays normally but you can see a pinkish colored hue over then entire screen. is this an easy fix? anyone know whats wrong with it?
check pics,
-alex
IMG_4653.JPG 320k .JPG file IMG_4654.JPG 285k .JPG file
ID:	70143   Click image for larger version
alexretro is offline
post #2 of 4 Old 06-16-2013, 06:37 PM
neonsky's Avatar
Bad video card, maybe?
neonsky is offline
post #3 of 4 Old 06-16-2013, 07:16 PM - Thread Starter
alexretro's Avatar
no, its the monitor. even without the pc or laptop plugged into it. it still shows the pink box. i own at least 8 monitors, my pc and laptop are like new. this is a free crt i got with a problem, even though i have led and lcd flatscreens i love crt and would like to use this crt.
post #4 of 4 Old 06-17-2013, 07:28 AM
gringito's Avatar
hello i have ,love, and swear by the fantastic E400 i would recomment a good internal cleaning .i have found color glitches like you describe are usually dirty, or cold welded components ,try taking it apart and blowing the dust out of it. .its worth it , set at 1280 by 1024 with 75 hertz refresh the monitor is the nicest ive seen! forget about plasmas!!
gringito is offline
Reply CRT Projectors
Denon Avr E400
