How to clean the C element and the face tube and to kill the fungus - AVS Forum | Home Theater Discussions And Reviews
Old 06-25-2013, 10:59 AM - Thread Starter
cencio's Avatar
Please can anyone help me to solve this problem before reinstall the elements and put the glycol?
Vincenzo
One of the most essential things of the life is to speak in the right moment and when you have important things to tell.
Otherwise you have lost an opportunity to keep silent
cencio is offline
Old 06-25-2013, 02:44 PM
draganm's Avatar
Quoted: 21 Post(s)
rinse everything thoroughly with Isopropyl Alcohol. This will kill off any spores and won't damage the c-element.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Old 06-25-2013, 04:48 PM - Thread Starter
cencio's Avatar
Done!
Many many thanks.
And now: you know that in Italy is very difficult (read impossible) to find the Freeze Coolant.
So I only use the glycol. Is it right the blend 70% glycol and 30% glycerin?
Vincenzo
cencio is offline
Old 06-26-2013, 05:44 PM
Tim in Phoenix's Avatar
Hello
Best to use triethylene glycol mixed 90/10 with distilled water. And replace the steel fillhole screws with stainless steel screws to avoid corrosion later.
Tim at E-Tech
Tim at E-Tech ooo ehometech@earthlink.net ......your Marquee Pro Shop!
Tim in Phoenix is offline
Old 06-27-2013, 06:26 AM - Thread Starter
cencio's Avatar
Hello Tim,
I'm glad to ear you.
Today I made some serches to find trirthylen glycol but it is very difficult.
So it is easy for me use the ethylen glycol. What is the right blend?
And then is it easy to find the new stainless steel screws?
Best Regards
Vincenzo
cencio is offline
Old 06-27-2013, 04:53 PM
draganm's Avatar
Quoted: 21 Post(s)
a lot of people use this and like it, non toxic,probably easy to ship to Europe.
http://www.orisonmarketing.com/IceclearPGX.html
draganm is offline
Old 06-28-2013, 09:41 AM - Thread Starter
cencio's Avatar
I'm already search to buy from this site but the selling is opened only for Canada and USA.
Probably I will use the triethylen glycol.
Many thanks
Vincenzo
cencio is offline
Old 06-28-2013, 04:54 PM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
I have stock and sell lots overseas.. email me at curtpalme at shaw.ca if you need some.
Cheers!
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
Old 07-04-2013, 01:34 PM - Thread Starter
cencio's Avatar
Originally Posted by Tim in Phoenix View Post
Hello
Tim at E-Tech
Hello Dear Tim,
I have made a disaster.
In these days I have drown the old glycol from each tube and clean all.
Before to put the new triethylen glycol in each tube I have cleaned each C-element and smear a very light coating of RTV Silicon around. Closed and fix all.
Today I have clean each hole up the tube and the little fillhole screw to deoxidize them. I have cleaned the hole with a wood toothpick with heron around. But unfortunately one toothpick has fallen into the blue camera tube.
The silicon is hard and it is impossible to pull the black face ring and the wood toothpick is into.
WILL BE IT A PROBLEM WHEN I WILL REFIL THE GLYCOL\WATER BLEND?
Best Regards
Vincenzo
cencio is offline
Old 07-04-2013, 04:24 PM - Thread Starter
cencio's Avatar
All solved..
Finally I pull out the black face ring and the C-element: removed the wood toothpick.
Vincenzo
cencio is offline
