sony vph g70 question..... (from a newb) help? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-25-2013, 11:10 AM - Thread Starter
brodykmb's Avatar
nevermind.. solved
brodykmb is offline
post #2 of 2 Old 06-25-2013, 01:50 PM
neonsky's Avatar
Just come on over here :
WWW.curtpalme.com
There is a ton of info on the site and forum. Plus Curt can set you up with a moome card for HDMI.
BTW the DirecTV is gonna look at you like your crazy. Where you located maybe someone here or on Curts forum can assist you if you're local.
neonsky is offline
Reply CRT Projectors
