Raise the Red Can - AVS Forum | Home Theater Discussions And Reviews
Old 08-08-2013, 12:29 PM - Thread Starter
Shelleybear's Avatar
Hi,
I have a Barco 808s that totally rocks.
However, I'm about 95% of the way to a perfect set-up and have found that I need to raise the red can just a tiny bit to bring it into true.
Can someone tell me where I can find the adjustment to do so?
It is flat ceiling mounted.
Everything else is PERFECT.
*can you tell I LOVE this projector*
Shelley
Shelleybear is offline
Old 08-10-2013, 08:06 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
You need to slightly adjust the red V **** control. Set the vertical shift setting in the menus to 50%, then adjust the control here:
http://curtpalme.com/Barco808_Layout3.shtm
Feel free to join our forum here, it's got a lot more CRTers on it than AVS, although AVS was very busy back in the day:
http://www.curtpalme.com/forum/index.php
Curt
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
