barco 801 data - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-30-2013, 11:37 AM - Thread Starter
Donald Maxwell's Avatar
I have a barco 801 data is there someone in Bournemouth dorset  uk that can help me set it up or may have a copy of the set up dvd  thanks
Donald Maxwell is offline
post #2 of 2 Old 09-30-2013, 05:33 PM
draganm's Avatar
Quoted: 21 Post(s)
Barco's are not too difficult, just make sure and read everything there is, skipping steps will ultimately cause problems down the road. Especially things like distance from the screen which is non-negotiable based on on your screen size.
Also,S-video and composite are 480i max resolution,you will need a transcoder to convert eiither component video or HDMI to RGBHV ,or run A signal directly fro ma personal computer with a VGA - RGBHV breakout cable. For the Barco 800's 1080i is your best choice.
All explained here
http://www.curtpalme.com/CRTPrimer_17.shtm
manuals
http://www.curtpalme.com/Barco500_Downloads.shtm
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
