U matic Sony VP-7040 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Harry Moore
post #1 of 2 Old 11-07-2013, 08:53 PM - Thread Starter
Harry Moore's Avatar
I posted in another thread i have a Sony vp-7040 u matic vcr i got it some time ago from a reuse shop ( last stop to the dump) ! but got it home and it played tapes fine no problems at all.
i tried it again a while back when i got some other tapes and its just loaded and none of the buttons works.
i just get a stand by light stay on.
When you power it up i can hear a relay or some thing electro mechanical switch on then the play button light comes on for a second or 2 and then the standby light is on and nothing on the button side of things work will not eject either ..counter number lights are on so i thing the power supply is fine .
Its a front loader i can see all the sensor leds seem to work and it also has a few tiny light globes not sure but i think they are just there so you can see the inside workings perhaps in case it screws a tape up ?
But nice if any one can help ....not sure if this has belts or not i have not looked under it .Any one that has worked on these machines might know any case thanks for reading good advice always welcome .
Harry
AvsMax likes this.
Harry Moore is offline
post #2 of 2 Old 05-03-2015, 02:19 PM
Liked: 0
Hi Harry, I'm having the same problem here. Did you get the solution?
Please, let me know.
Thanks in advance.
Max
AvsMax is offline
Reply CRT Projectors
