Projector and Bluetooth Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-15-2014, 10:37 AM - Thread Starter
kevin is lost's Avatar
I have a Casio XJ-M245 projector that I have borrowed for use for a Superbowl Party. I am making my own screen based upon alot of the helpful threads here at AVS.
Question I have is sound. The Casio has a decent built in speaker, but not enough to really be heard when there will be about 25 people in the room.
Setup will be :
Time Warner Cable Box to Casio Projector via HDMI cable.
Is there a way to get a blue tooth device off the projector so that I can place speakers in different locations around the room?
Other option I had was to borrow someones PA AMP and just use the that for singular sound source.
kevin is lost is offline
post #2 of 2 Old 01-16-2014, 08:14 PM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
You are indeed lost Kevin, you need to post in the digital section of this forum. smile.gif
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
Reply CRT Projectors
