Sony KP-5020 with Screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-31-2014, 09:29 AM - Thread Starter
iKokomo's Avatar
I have a Sony KP-5020 that we inherited about 15 years ago and we used it a lot, but now the tubes are getting dim and the colors are starting to bleed. I was wondering what the best thing to do with this TV set and Sony Screen??
Thanks a lot!
iKokomo is offline
post #2 of 2 Old 02-02-2014, 05:23 PM
draganm's Avatar
Quoted: 21 Post(s)
it's amazing you watched it that for that long, one 75 ohm antenna input? it's ready for a museum or electroncis recycling, but if you want ot fix the bleeding colors then most likely there's fungus in the CRT Coolant (liquid chamber in front of the tube and behind the lens)
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
