Vidikron Vision One 9" CRT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-30-2014, 07:30 AM - Thread Starter
KenB3's Avatar
Just a quick question, The unit powers up, Fan runs but NO bulbs
and no error lights are lit on the rear of the unit
any idea's ???
this is a great unit
KenB3 is offline
post #2 of 3 Old 04-30-2014, 08:11 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
two common issues: Bad HVPS or bad H deflection board. There's no way to know which one it is without either swapping in another board, or testing your boards in another set. I can test/repair/replace those for you if you want to send them in. Email me at curtpalme at shaw.ca if you want more info.
Cheers!
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 3 Old 04-30-2014, 02:25 PM
draganm's Avatar
Quoted: 21 Post(s)
post you general location (city-state) and there's a good chance there's a CRT guy near by that can help
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
Reply CRT Projectors
