problem with Barcovision 508 - AVS Forum | Home Theater Discussions And Reviews
Old 05-05-2014, 11:05 AM - Thread Starter
semajjames's Avatar
Hi having now found the right forum ,,,,,
       I have just got a Barcovision 508 projector and no nothing about them !!!!
So i connected it to my pc using the S video in put and powered it up expecting the screen to just light up ,,but it did not ,,,
so the stand by seems to work the led is red for off press stand buy button led goes green and more green leds on the internal boards light,,,,, the base of the tubes starts to glow grange but no screen
the pc seems to think is has a tv plugged in which seems fine
BUT on the back there is 1 orange led lit the COINCIDENCE led this is lit so does anyone know what this led means or am i missing a step somewhere
cheers
semajjames is offline
Old 05-06-2014, 11:25 AM
draganm's Avatar
Quoted: 21 Post(s)
most likely a high voltage quad or splitter problem and even in todays market the prices on those parts used is 10X what your machine would be worth if it was running. Check CL and find something for free, look at this list for ideas
http://www.curtpalme.com/Projector_Rankings.shtm
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
