Yoke wire location? - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2014, 07:20 PM - Thread Starter
Liked: 0
Unhappy Yoke wire location?
I am having issues locating the yoke wires to reverse my projectors image. It is a Sony VPH1001Q. It was originally ceiling mounted, now I would like it to be used right side up. Will I have to reverse both the horizontal and vertical wires? What colors are the yoke wires in the picture and which ones need to be switched? Thanks very much.
Name:	Whole unit .jpg
ID:	156945   Click image for larger version
ID:	156953   Click image for larger version
ID:	156961   Click image for larger version
Piechest is offline
Old 07-11-2014, 07:55 PM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
Page 20 of the Installation Manual should help you
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
Old 07-11-2014, 09:16 PM - Thread Starter
Liked: 0
Wow that was much easier than anticipated! Can't thank you enough. All the best
Piechest is offline
Old 07-12-2014, 09:41 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Piechest, come join our forum at the top of the home page of my website. There's far more CRT owners there than there are here.
Cheers!
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
Old 07-12-2014, 04:46 PM - Thread Starter
Liked: 0
Cheers!
Will Do! Thanks!
Piechest is offline
sony vph1001q , upside down image , yoke reversal
