Barco Data 600: unknown condition - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-04-2014, 05:20 AM - Thread Starter
hiaschey's Avatar
Liked: 0
Question Barco Data 600: unknown condition
Hey guys,
I got a used Barco Data 600 for free some time ago, but the Tubes just won't light up, though
I soldered the "Remote"-Board, which didn't really do anything either.
Apart from the fan, some high-pitch noises and a few internal LED's, it doesn't seem to do anything.
I also tried playing around on / fully disconnecting the Convergence-board, but apart from the high-pitch noise changing to something a bit buzzing (when the hor amp poti goes into low position), no difference.
When pressing the switch near/on the testsignal generator, the high-pitch noise goes away for some time, but that's all.
(Also, one red LED and one green LED light up, as well as three orange ones near the RGB-knobs on the right side. All of the Tube's bases light up a little orange when turned on)
(checked all obvious fuses)
(haven't looked into the black box adjecent to the 35KV Transf.)
Stuff:
Barco data 600 + Barco Rgb-TTL-EGA-Conversion-box thinghy (connected via 4 coax + remote cable) + self-soldered "remote" (checked +17V)
(no VGA-Rs232 cable so far, as i won't build one if none of the tubes light up)
Multimeter, analog Oszi (if necessary), Barco Data 600 Manual, some EE-Student skills
Got the manual from curtpalme.com, will be looking through the service manual soon.
Any hints?
--Thomas
EDIT:
According to http://www.curtpalme.com/Troubleshoo...ps_Barco2.shtm the red LED might indicate a bad V/H-Card?
Does anyone know wich components are especially damned to fail (apart from capacitors&fuses?)
Do i really need to disconnect all tubes individually according to http://www.curtpalme.com/Troubleshoo...s_Barco3.shtm? (during power-off, reasonable safety-time for cap-discharge)
ID:	196018   Click image for larger version
ID:	196026   Click image for larger version
ID:	196034   Click image for larger version
hiaschey is offline
post #2 of 5 Old 08-04-2014, 07:09 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
If the red light on the focus board isn't on, the set is probably working. The little plugin remote on the back is mandatory as that controls the brightness and contrast. I have one or two kicking around if you're missing it, or are unsure if it works. Also, you need an RGBHV input signal for the set to do anything.
Why not join the forum on my site, there's lots more people there.
I've thrown out all BArco 600 parts last year, as no one had these sets anymore, but it doesn't sound like you need much, if anything for this one.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #3 of 5 Old 08-08-2014, 06:17 AM - Thread Starter
hiaschey's Avatar
Liked: 0
Thanks, i'll try soldering a EGA-VGA adapter according to http://www.ambery.com/db9todbadca.html and have a look at your site's forum.
hiaschey is offline
post #4 of 5 Old 08-10-2014, 08:22 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
Wait, why? Don't plug a VGA signal into that 9 pin port, that's for the little 'remote' box for the brightness, contrast, etc controls!
post #5 of 5 Old 08-10-2014, 08:44 AM - Thread Starter
hiaschey's Avatar
Liked: 0
Na-ah!
That's what the 15 pin connector is for, which is labeled "Projector controls" and for which i built that remote, according to a pdf on your site. (see my 1st pic)
There are two Ega inputs, one being 1x 9pin connector (INP B), and the other one (INP A) being 2x 9pin connectors.
I plan on using INP B, as it features much of the pins in that link i posted (except for low/high lights and csync, which i'll leave out. The pins have a different order, too)
hiaschey is offline
Reply CRT Projectors
600 , barco , data , projector , unknown
