Repair a Dwin HD 700 blue crt board? - AVS Forum | Home Theater Discussions And Reviews
Old 08-19-2014, 03:43 AM - Thread Starter
Debonaire's Avatar
Quoted: 149 Post(s)
Liked: 24
How much to repair or get a new board?
I took apart my broken Dwin. Fiddling with it a bit the red went out. Then I pushed the red crt board tight and it came on again.
I tried cleaning the blue board by wiping it with a cloth, along with the connectors. No go!
Debonaire is offline
Old 08-19-2014, 08:21 AM
Curt Palme's Avatar
Quoted: 32 Post(s)
Liked: 58
if the blue test patterns don't work as well, then it's most likely a bad socket. If the test pattern works, then check the cable between the BNC inputs and the motherboard.
It's going to be cheaper to just sell you a replacement working CRT socket. I have stock, pls contact me at curtpalme at shaw.ca
thanks!
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
