Sony VPH 1272 + RGB input - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-01-2003, 09:27 PM - Thread Starter
pressureEze's Avatar
I recently purchased a Bravo D1 DVD player and intended to run it's DVI output to the RGB input on my sony VPH 1272. When I select the DVI output on the player and select the appropriate input on the projector, I get no output at all. Cycling though all the DVI output resolutions (480p, 720p, 1080i) all yield no output at all. I originally thought it to be a problem with the player or a cabling problem, but I can hook the same cables to the DVI output on my video card in my PC and I get some playback on the projector, but only before windows actually loads. When the desktop loads and the resolution changes, it's like the projector loses the signal. Sometimes I even see it constantly trying to resize itself. The projector and player both work great with the s-video. I've looked all around and can't seem to find anything to change or adjust on the projector to accomodate these different video sources. Any help at all would be greatly appreciated. Thanks.
pressureEze is offline
post #2 of 2 Old 09-02-2003, 03:39 AM
Tom Rosback's Avatar
Here is some info on your player you might find helpful:
http://www.projectorcentral.com/bravo_d1.htm
Looks like you have to toggle through some undocumented options on the remote to activate the DVI port. Setup the DVI output resolution to 480p, at least to start.
I assume you are using the C1-C5 analog outputs on the DVI connector into the 1272Q. There should be 5 lines coming out of the DVI port, RGBHV.
Correct?
If so, on the PJ option menu, set sync to y/c. If you only have an RGB output, set sync to SonG, and see if the player has an option to set Sync on Green.
I won't have internet access until this Friday, so won't be able to respond until then.
JVC RS 500, Stewart 106" Studiotek 130
McIntosh MC 2301 x 3, MC 602
McIntosh MX 151, C500T, MCD 1100, Oppo BDP-95
Sonus Faber Amati Futura, Amati Homage Vox, Proac Response 1sc
Nottingham Dias TT, Ace Space Arm, Sumiko Palo Santos cartridge
Tom Rosback is offline
Closed Thread CRT Projectors
