Anyone for a DVI-D Input Card for Sony crt? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 206 Old 02-25-2005, 05:07 PM
techman707's Avatar
Terry,
Since the output from the display card is DVI, what difference should the cable length make since the signal would remain in the digital domain all the way to the card on the projector, right?
Bruce
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." -Ghandi
techman707 is offline
post #92 of 206 Old 02-25-2005, 05:10 PM
bravozulu's Avatar
I think he means comparing it with a long VGA cable - more of a "real world" comparison. The DVI image should be, as you say, untouched.
Pete
Want good radio? www.kexp.org - where the music matters.
bravozulu is offline
post #93 of 206 Old 02-25-2005, 06:32 PM
Don Rombach's Avatar
So the coming lack of analog HDTV material means the extinction of the three eyed dinosaur:rolleyes:
Pssst buddy, wanna buy a chip:D
Big D
Don Rombach is offline
post #94 of 206 Old 02-25-2005, 08:07 PM
Chuchuf's Avatar
Bruce,
What Pete said. Shouldn't make any difference on the DVI cable so long at the max length isn't exceeded. I want a real world VGA comparison.
Andrew pointed something I found interesting last night. That is that NVidia in their design and implementation is doing a very good job with D-A.
And as an aside, I tested that $4K video cable I had gotten from someone and could see no difference between it and my Canare cable.
Terry
AVS Marketplace or Videogon are the places to see F/S ads
Chuchuf is offline
post #95 of 206 Old 02-25-2005, 08:17 PM
Tinman's Avatar
Liked: 33
How the heck did I miss THIS thread altogether????
Is there any talk of making a DVI card for the NEC? Maybe for the ISS-6010 switcher? Someone fill me in, please.
Marc
Welcome to the darkside.....
Tinman is offline
post #96 of 206 Old 02-25-2005, 09:59 PM
curtisG's Avatar
Originally posted by hdtvme
Do you recall if the Macrovision CP was turned off in the "secret menu" on the Momitsu? Correct me if I'm wrong, but if Macrovision is not disabled the DVI-D will have HDCP active.
I don't know. This was a brand new Momitsu Network version out of the box. Clarence - do you recall if it was?
--curtis
curtisG is offline
post #97 of 206 Old 02-26-2005, 06:27 AM
Chuchuf's Avatar
Marc,
I'm sure that Mike could make this card available to any PJ he wanted to simply by macing it into an external enclosure w/ DVI in and RGBHV out. The proto I have fits in a Sony.
I suggested this once before on Petr's transcoder, but if I were going to design a widget to go into the input of a PJ, I would consider a motherboard/daughter board arrangement so that the motherboard could be made PH specific and the daughter board containg the circuitry of what the device does.
Terry
Chuchuf is offline
post #98 of 206 Old 02-26-2005, 06:31 AM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 9999
--curtis
I don't think you even get 1080i/720p out of the DVI pins if Macrovision was still enabled (even using the DVI-I -> analog HD15 adapter).
And if you got it from extremephono.com, I'm pretty sure they disable it for you.
But you can check to see...
http://www.keohi.com/keohihdtv/brand...mitsuv880.html
The Momitsu will pass a analog VGA compatible signal if you disengage the Macrovision protection. Assuming you've got a newer firmware version you can access the hidden menu by using button combination "down-updown-up-right-left" on the remote control.
  • Power on DVD player with the Aconda hooked up via a component/RCA video port and a DVI-I -> VGA cable simultaneously.
  • Take any discs out of the DVD player
  • When blue screen graphics shows, hit the following button sequence on remote control "down-up-down-up-right-left"
  • There a menu will now show up allowing you to select your Region and Macrovision settings.
  • Change the region you want. "0" makes the Momitsu region free.
also http://www.gumboot.co.nz/forums/topic.asp?TOPIC_ID=89
Clarence is offline
post #99 of 206 Old 02-26-2005, 10:03 AM - Thread Starter
hdtvme's Avatar
Marc
I'm open to adapting the design to other projectors or Terry's motherboard / daughterboard idea. With the question of G series compatibility answered, one major hurdle remains: getting > 60Hz refresh out of an NVidia DVI port. This does not appear to be an EDID problem as I have the limits there set well above what 1440 x 960 72p would require. Also, several ATI cards I have tried have no problems going above 60Hz on DVI.
At this point, I consider the hardware fully compatible with anything that can accept an IFB-11.
The firmware may still need to change depending on what it takes to get the NVidia cards outputting correctly.
hdtvme is offline
post #100 of 206 Old 02-26-2005, 10:21 AM
Chuchuf's Avatar
And I think more testing should be done with other DVI sources besides a HTPC.
Terry
Chuchuf is offline
post #101 of 206 Old 02-26-2005, 10:36 AM
Tom.W's Avatar
Iv'e read other posts on problems with the Nvidia DVI output.I don't think your converter is at fault.
Tom.W is offline
post #102 of 206 Old 02-26-2005, 10:45 AM
Das444's Avatar
New at all this CRT stuff. It sounds like I would like one for my 1252q. When will they will be available?
Dan
Das444 is offline
post #103 of 206 Old 02-26-2005, 12:25 PM
techman707's Avatar
Terry
I don't think other sources should present any unforeseen problems.
Now all you have to do is buy a cheap HDTV with a DVI/HDCP input and strip out the HDCP chip they won't sell.:D:p :D
post #104 of 206 Old 02-26-2005, 02:26 PM
Art Sonneborn's Avatar
Quoted: 241 Post(s)
Liked: 306
I'm happy to see that progress is being made. What exactly is involved in installing this card into something like a G90 ?
Art
My HT
iRule rules my theater
Art Sonneborn is offline
post #105 of 206 Old 02-26-2005, 02:41 PM
Clarence's Avatar
Quoted: 284 Post(s)
Liked: 9999
Treat it just like an IFB-11. It slides right into the projector input slot.
Art, how do you usually feed the same image to both G90's?
Also, do you have a Sony switcher?
Clarence is offline
post #106 of 206 Old 02-26-2005, 03:03 PM
Chuchuf's Avatar
Art,
Like Clarance said it simply plugs into one of the other available slots for inputs in the PJ. You then select input B and there it is. Since the G90 (or G70 or D50 I assume) see's this as an RGBHV input yu have all the color controls you would have with RGBHV like bias, gain, etc.
Bruce.....that's the ticket.
Terry
Chuchuf is offline
post #107 of 206 Old 02-26-2005, 04:05 PM
Quoted: 241 Post(s)
Liked: 306
Clarence,
I have an Extron distribution amplifier that splits the RGBHV signal. I do not have a Sony switcher.
Art
My HT
post #108 of 206 Old 02-26-2005, 04:07 PM
Quoted: 241 Post(s)
Liked: 306
Art,
Terry
Sounds wonderful for the electronically challenged such myself.
Art
My HT
post #109 of 206 Old 02-26-2005, 06:25 PM
Tinman's Avatar
Liked: 33
Well, I'd certainly be interested. I have Petr's transcoder, which after a small mod is now happy with whatever I feed it. I am interested in future-proofing my system as much as possible. For me, the DVI card would have to be an ISS-60XX input card, since the NEC PG series does not use input modules. I have enough NEC's to last me for at least 20 years, so I am not too motivated to find a G90 or XG just for the input slot. Unfortunately I don't have time to monitor all the threads here at all times, so if I could be notified if an ISS card or stand-alone unit is in the works, I'd be VERY interested.
Marc
Tinman is offline
post #110 of 206 Old 02-27-2005, 01:00 AM
moome's Avatar
i have a external model for DVI-VGA, see my web
http://221.169.10.62
moome is offline
post #111 of 206 Old 02-27-2005, 10:33 AM
Tom.W's Avatar
Here is one with a built in linear power supply and is HDMI compatible.It also has a built in 1080i > 1080p scaler.Mike Parker will have one for testing at his next gathering with the optional SDI input :)
Tom.W is offline
post #112 of 206 Old 02-28-2005, 06:09 PM - Thread Starter
hdtvme's Avatar
Update:
A Momitsu V880 is on the way here (thanks Ed!) so that compatibility will be assured with the firmware that ships on the IFB card.
Everyone who said they wanted 1 or more cards should have received a PM from me today confirming. If you didn't get a PM and want to order, please PM me or post here ASAP. Also, anyone that wants off the list let me know so I don't over-build.
hdtvme is offline
post #113 of 206 Old 02-28-2005, 06:11 PM
Graham Johnson's Avatar
Just to confirm that these WILL DO 1080p in a 1292 !!
Graham
Graham Johnson is offline
post #114 of 206 Old 02-28-2005, 06:54 PM - Thread Starter
hdtvme's Avatar
Yes, 1920 x 1080p, 60Hz refresh is well within the card's capability and is tested.
hdtvme is offline
post #115 of 206 Old 02-28-2005, 07:32 PM
Umm will it support 50hz ??
As 60 hz way is outside the bandwidth capabilities of most projectors !!
Graham
post #116 of 206 Old 02-28-2005, 08:24 PM - Thread Starter
hdtvme's Avatar
50Hz is no problem. I tried it on my 1292 just now to be sure.
hdtvme is offline
post #117 of 206 Old 02-28-2005, 08:51 PM
Thanks Mike. This is very cool can't wait now.
Graham
post #118 of 206 Old 03-03-2005, 11:07 AM - Thread Starter
hdtvme's Avatar
The IFB-DVI is now being offered in the Power Buys section.
hdtvme is offline
post #119 of 206 Old 03-03-2005, 11:17 AM
LJG
LJG's Avatar
Quoted: 330 Post(s)
Liked: 142
Other than the HDCP issue, what advantage is there running a DVI input into the G90U vs RGBHV ?
Lon
LJG is offline
post #120 of 206 Old 03-09-2005, 05:21 PM - Thread Starter
hdtvme's Avatar
The Momitsu V880 is now tested and guaranteed to work with the IFB-DVI, including custom resolutions / refresh rates.
HDMI video compatibility is also guaranteed when using HDMI to DVI patch cables.
They will begin shipping early next week.
hdtvme is offline
Closed Thread CRT Projectors
