RGB Breakout Cable:# of Pins? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-14-2005, 05:57 PM - Thread Starter
blue360's Avatar
Noticed that my RGB Breakout cable only has 14 pins instead of the 15 that most show in pictures. There is just an empty hole where one of the pins should be!Been having some trouble with a Barco i just set up and am wondering if this could be the problem .Thanks for any replies!
blue360 is offline
post #2 of 6 Old 12-14-2005, 06:02 PM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
Which pin is missing? Most likely it's only the pin required for the old energy saving feature implemented in many computer monitors. It would not be needed for any CRT projectors.
Otherwise, check this page for a layout of the pins:
http://www.bbdsoft.com/video.html
Welcome to the forums!
"The boom is dead, long live the bass"
CZ Eddie is offline
post #3 of 6 Old 12-14-2005, 06:36 PM - Thread Starter
blue360's Avatar
Pin # 9(no connect) is missing according to the link you posted.So this shouldnt be a problem then, right? Thanks for the speedy reply!
blue360 is offline
post #4 of 6 Old 12-14-2005, 07:03 PM
Tom.W's Avatar
Pin 9 is not used for anything.But are you inputting a negitive sync ? Which also raises another question.Does anyone know if Moome's DVI card is outputting negative or positive sync ?
Tom.W is offline
post #5 of 6 Old 12-14-2005, 09:53 PM
Tom.W's Avatar
Apparently Positive sync only as I just heard from Moome...Never mind ! :( Damn negative sync ! :mad:
Tom.W is offline
post #6 of 6 Old 12-14-2005, 10:27 PM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
Freakin Barco's! :P
CZ Eddie is offline
Closed Thread CRT Projectors
