Rip Crt Forum - AVS Forum | Home Theater Discussions And Reviews
 254Likes
Closed Thread
post #1 of 845 Old 09-27-2005, 01:40 AM - Thread Starter
dokworm's Avatar
Liked: 25
If only it would work on a projector - the images are well worth a look.
http://www.tomshardware.com/hardnews...23_170519.html
DON'T feed the troll.
dokworm is offline
post #2 of 845 Old 09-27-2005, 04:12 AM
mp20748's Avatar
Quoted: 106 Post(s)
Liked: 26
Man, it's been over two hours since someone has posted the words "contrast ratio", and Darin has yet to chime in.
He's either on vacation, or there must be something wrong with the special device that alerts him of these posts.
It's all about the performance... Got Marquee!
High Performance Marquee Video chain modifications.
mp20748 is offline
post #3 of 845 Old 09-27-2005, 04:53 AM
kschmit2's Avatar
$49k is all I can say
kschmit2 is offline
post #4 of 845 Old 09-27-2005, 04:55 AM
techman707's Avatar
LOL - :p :D :p
"The greatness of a nation and its moral progress can be judged by the way its animals are treated." -Ghandi
techman707 is offline
post #5 of 845 Old 09-27-2005, 11:13 AM
Art Sonneborn's Avatar
Quoted: 242 Post(s)
Liked: 307
Yea very impressive. If you measure on off CR using direct measurements from the tube, a good LC CRT like the G90 is probably close to this as it is.
Art
My HT
iRule rules my theater
Art Sonneborn is offline
post #6 of 845 Old 09-27-2005, 12:47 PM
Outsider787's Avatar
It's all great that we can make devices that have a huge contrast ratio, but what about the material to be displayed?
Currently, we can only capture 5-6 f-stops with either film or digital, which is likely the amount of dynamic range most display devices are currently capable of.
But I guess if the display industry starts the push towards more dynamic range, the recording industry will likely follow.
If it's worth doing, it's worth doing to excess!
Outsider787 is offline
post #7 of 845 Old 09-27-2005, 12:52 PM
darinp2's Avatar
Quoted: 1129 Post(s)
Liked: 1765
No matter how many f-stops you have, if the lowest value is supposed to be zero light, then it takes the perception of infinite on/off CR to correctly represent that one to a viewer. I've never seen any standard that called for the darkest value to be anything other than no light.
--Darin
Ericglo likes this.
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #8 of 845 Old 09-27-2005, 01:12 PM
KenLand's Avatar
Darin,
I think you are dismissing Outsider's line of reasoning too quickly.
I design and build scanners not cameras, but I'm sure there is some minimum brightness below which the movie cameras won't register.
I think it would be a useful exercise to determine the minimum light sensitivity of modern HD cameras and use that as a practical goal for projector black level. It's not going to be zero light no matter what the spec says.
Why spend a bunch of money reproducing what the best movie cameras can't capture?
I'll bet Wigggles knows this off the top of his head.
Ken
KenLand is offline
post #9 of 845 Old 09-27-2005, 01:20 PM
atomiccow's Avatar
They must look better in person because my perception of the photos is that the high contrast display looks terrible. The wizard has poor color and the whites are blooming an insane level of blue.
atomiccow is offline
post #10 of 845 Old 09-27-2005, 01:35 PM
darinp2's Avatar
Liked: 1765
Originally Posted by KenLand
Darin,
Any device can get no light. Just put the cap on. It is basically the next step up that it can differentiate from no light that is what is used for those f-stop calculations.
If the camera doesn't "register", do you think it should be played back with some level of light? I could see that if the person doing the telecine saw that it should have been something other than no light and wants to encode it above video 16.
I can see where some people may want to raise the absolute black level because the step from the lowest to the next lowest is too large, but you give up the ability to reproduce situations where we perceive no light, as can happen in real life. And as far as whether you want to raise the lowest light level because of the step to the next, have you ever seen any standard that called for anything higher than no light for the lowest value?
--Darin
Ericglo likes this.
darinp2 is offline
post #11 of 845 Old 09-27-2005, 01:40 PM
KenLand's Avatar
Just as a quick random google check. Here is the spec on a JVC 720P HD camera
http://www.smsprod.com/hdcinema/aj-hdc27f4.html
Minimum Illumination
0.7 lux (F1.4, +36 dB gain 59.94p)
So I'm assuming anything not illuminated to this level is lost. (going to be very noisy with 36 dB gain!)
How would this translate to black level at the viewing position of a FP displaying this camera's output?
Ken
KenLand is offline
post #12 of 845 Old 09-27-2005, 01:46 PM
darinp2's Avatar
Liked: 1765
Let's say they point the camera at something where basically no light is getting registered. Then the person doing the telecine transfers it. What should they do, encode it to display some light? Maybe if they can see that the scene called for it for some reason, but why should a "scene" with no light get played back with light (or more light)? The only reason I can see is the reason above with the large step between the bottom 2 values, but dithering can be used for much of that. As far as noise, dealing with that is one of the tasks of the person doing the telecine or some version from the master.
If a camera captures nothing then the person doing the telecine can decide to raise the level above video 16 by dithering or whatever if the scene looks like it should be done that way, but if they think the scene should be a blackout then having the ability to encode it and display it that way makes complete sense to me. Why would we want to limit this ability? And if you don't think that a frame of all video 16s or lower should be displayed with no light, what light level do you think should be used in the end?
Let's just take "Cast Away" as an example. Tom Hank's character blacks out. Should the full frames for the blackout portion be displayed with some light, and if so, why?
--Darin
Ericglo likes this.
darinp2 is offline
post #13 of 845 Old 09-27-2005, 02:03 PM
KenLand's Avatar
Ok 16 is black and can vary. Obviously there is some limit to this. You wouldn't want 100 footlamberts of black most likely.
17 must be brighter than 16 and should be where the sensitivity of the camera is dovetailed into your brightness scale.
It seems unnatural for 16 to represent 0.000 lux and 17 to jump to .700 lux. (the min illuminance that will be descernable)
Maybe not, but I think its a useful discussion. Maybe thats exactly what we want, but although I can't find the words, it seems that there is some relevance that no information between 0.000 lux and .700 lux is ever present in the material.
Assuming for arguments sake that .7 lux is typical.
Ken
KenLand is offline
post #14 of 845 Old 09-27-2005, 02:51 PM
lamestlamer's Avatar
CCDs used in astronomy can detect single photons. I don't know of any display that has that sort of precision. Of course, any pixel that recieves more than 2^16 photons will begin to blead into the surrounding pixels, resulting in the cross shaped glare that is so common in those beautiful 3-color images of deap space.
My guess is that they have a OLED stacked with a standard LCD. That would explain why the ANSI CR is lower (as seen in the white box's halo). If I wanted to drive my 24" CRT monitor as hard as possible, I bet I could get a similar image.
Michael
lamestlamer is offline
post #15 of 845 Old 09-27-2005, 03:06 PM
deronmoped's Avatar
The guy doing the transfer owns a LCD PJ and hates the fact that CRT's can do absolute black, so every chance he gets he sets the threshold for absolute black at what his LCD can do.
There are just mean people out there:)
Deron.
CRT Videophile
deronmoped is offline
post #16 of 845 Old 09-27-2005, 03:09 PM
darinp2's Avatar
Liked: 1765
I understand that, but here is where a person converting from film to digital (doing the telecine) can dither between adjacent pixels with 16s and 17s to get values that our eyes will see as levels between them and probably one reason you want a person with some intelligence and skill doing the telecine. And because ANSI CRs aren't perfect the 16s in mixed scenes won't actually end up getting zero light even if the on/off CR of a projector was infinite. I could see some day in the future where a display device has so much ANSI CR that some people complain that the blacks are too black in many mixed scenes, but I don't think we are there yet and it would also take screens or rooms that could hold super high ANSI CR.
This is kind of funny, but it is somewhat frustrating that things near black are encoded wrong in so many cases for projectors that can go very dark. While this work is generally done on CRTs, they are CRT monitors (not front projectors) and my understanding is that there is light in the room and I believe the monitors are calibrated to between about 32 and 36 ft-lamberts. Much different than what I believe most people here have for their setups.
--Darin
Ericglo likes this.
darinp2 is offline
post #17 of 845 Old 09-27-2005, 03:46 PM
KenLand's Avatar
Darin,
But there is no information between 16 and 17 if 16 and below is reserved for the blackest black and 17 is the first value the camera can see.
So the perfect projector displaying real material from our real camera would jump from 16 = 0.000 lux to 17 = .700 lux.
There is no infomation below .7 lux. You can shift it all down to a certain extent, but you're not going to want the camera's .7 lux output to map to 0.0 lux.
So it's debatable how far below first light you need or want to go.
Along the same line. This HD camera will measure up to 2000 lux, so max CR is 2000 / .7 = 2857:1
So if this were a typical movie camera then movie content would contain no more than 3000:1 On/Off contrast.
I think this information is useful for setting projector performance goals and calibrations. If you know your content has 3K:1 CR do you want to expand it to 15k:1?
I'm not sure.
Ken
KenLand is offline
post #18 of 845 Old 09-27-2005, 04:18 PM
darinp2's Avatar
Liked: 1765
That is why you want somebody intelligent doing the telecine. You could just have a machine do it if all you want is 1:1 mappings.
If the camera somehow got .7 lux, I was doing the telecine and saw that it shouldn't have and the scene would be more correct if it mapped to 0 lux, then I would definitely want to map it to 0. Also, I don't know if the camera indicates that it got .7 lux if it gets no light or if it is a less than .7 lux case, but either way the issue is really the same.
If you choose a floor higher than zero light for the lowest value then you have tied the hands of the person doing the telecine and then the display, so why would you want to do that? Values in between can be chosen with dithering, as I mentioned?
I don't think that would be the on/off CR. That would be the video 235 to video 17 CR unless you want to map video 17 higher and make the lowest output value be .7 lux . You aren't suggesting that video 16 should map to .7 are you? If so, why? Maybe you want it to map to half that or 0.35, which would be closer to 6k:1, but that is arbitrary.
You seem to be making an assumption that if the camera gives its lowest reading then it must have been looking at .7 lux, but that isn't the case. It will indicate that for no light also as I said. And CR for a capture device where the CR is calculated by using a +1 on the lowest end kind of measurement is different than CR for a display device where the lowest output value is used. The reason for the +1 kind of measurement for capture devices is because of that unknown range at the bottom and that since all of them can be put into situations with no light the method of using the actual lowest they can receive would be pretty much useless. But, that doesn't apply to displays.
Put another way, if you know the scenes filmed had more than 3k:1 CR (or an intelligent person can tell that they should have), why would you limit the display of them to 3k:1? Why should a blackout that somebody tried to capture on film be displayed with light? Setting the standard for lowest value to higher than zero limits what can be shown. And that is one reason no standard calls for the lowest value to be higher than zero. At least I can't find any. Rec. 709 sure doesn't since the lowest position calls for no light.
It seems that what you are proposing is that when the camera doesn't know how much light it is getting (it is outside its accuracy range on the low end) you should assume it was the brightest possible to get that (or .7 lux in this case) when playing it back. While I can see how somebody might jump to that originally, I don't see how that position is very supportable when looking at what making this assumption and limiting the range of things that can be displayed means.
--Darin
Ericglo likes this.
darinp2 is offline
post #19 of 845 Old 09-27-2005, 05:41 PM
KenLand's Avatar
Do whatever you want with 16 (and below) and 235 (and above), but the camera can only capture .7 to 2000 lux and has 17-234 to map the measured levels. Or perhaps 16-235.
Whatever the brightness you pick to map the dimmest detail possible to it was .7 lux in reality. I think its fine for black or below black to dip below this, but to say it has to expand the CR from the signals maximum of 3K:1 to 200k:1 is not a good idea unless you know what you're doing.
If you for instance make the bottom of your gamma curve 0.0000 fL then you will loose shadow detail or at least severely distort the scene captured by the camera, because anything above absolute black is at the equivalent of .7 lux.
Basically its not a good idea to map your whopping 220 possible levels to onto a 200K:1 CR. That would be an incredible gap between any two adjacent values.
A better setup would map the real 3K:1 in the signal onto say 17-234/235 and reserve 16 for the blackest black your projector can muster.
Ken
KenLand is offline
post #20 of 845 Old 09-27-2005, 06:03 PM
darinp2's Avatar
Liked: 1765
The dimmest that the camera could ever get was 0-.7 lux. It doesn't know what it was at that point, so it seems that you are back to assuming that everything here was at the top end of that, or .7 lux. Do you agree that if the camera says .7 lux then you don't know if it was getting .7 lux or something lower? If it can do .7 lux accurately then the same thing applies to .6 lux or lower.
Somebody doing a telecine sure better know what they are doing.
If .7 lux is your lowest then you will lose shadow detail because now you have to raise the next level enough to get a just-noticable-difference, even in mixed scenes. How are you proposing that you get shadow detail by mapping "black" to .7 lux? You are claiming I will distort it by using 0 lux, but you are proposing distorting it by mapping everything in the 0-.7 lux case to .7 lux from what I can see.
How do you figure that? 200k:1 on/off CR doesn't tell you what the gap is between two adjacent values (not even counting dithering). Do you believe that the gap between .0001 and .003 ftL is an incredible gap? Why? If you are just looking at the 200k:1 to 3k:1 looking like a big gap, then you could look at the fact that every standard that calls for zero light for the lowest level (as every one I've seen does) calls for basically an infinite CR to some smaller CR between the lowest level and the second lowest level. But in absolute light terms the gaps aren't big like that.
We have been talking about video 16 the whole time, so you now seem to be proposing basically what I've said (other than me saying that the person doing the telecine should have some control, as they do). On/off CR is video 235 to video 16, not video 235 to video 17. That is a different matter and if 235 to 17 is 3k:1 it does not mean that 235 to 16 could not be 200k:1.
And how black should the projector be able to muster for a blackout in order to not have any room for improvement in this area? If you say more than 0 ftL, then based on what?
As an example, imagine a scene with a light on in a room and your 0.7 lux camera shooting this scene. The end of the scene consists of the light being dimmed slowly until there is no light. Basically, a fade-to-black. Then that holds for a few seconds. If a person was doing the telecine or transfer, how do you think they should encode this as it fades out? And how should a projector display it? Should light be shining on the screen during those few seconds where the blackout is held and should the viewers be able to see the screen? If so, how many ftL (or CR to 100 IRE) do you propose would be ideal for the blackout?
--Darin
Ericglo likes this.
darinp2 is offline
post #21 of 845 Old 09-27-2005, 06:12 PM
cmjohnson's Avatar
Quoted: 29 Post(s)
Interesting. If I interpret the description correctly, what they have there is actually a stacked display. The LED backlight is a full color active matrix display in and of itself,
or at the very least it's a monochrome (black and white) active display, if I interpret this right,
and in front of it is the LCD assembly. So the backlight is a variable light source on a per-pixel basis.
Brute force thinking. About as subtle as a hand grenade in a barrel of oatmeal.
I've thought of that one before. A pity I didn't have any way to turn it into a real idea.
CJ
cmjohnson is offline
post #22 of 845 Old 09-27-2005, 07:15 PM
KenLand's Avatar
Darin,
"On/off CR is video 235 to video 16, not video 235 to video 17. That is a different matter and if 235 to 17 is 3k:1 it does not mean that 235 to 16 could not be 200k:1."
Ok, we're in agreement. Every value other than the two extremes should be in the neighborhood of reality.
My jury is still out on whether you want such a large gap between 17 and 16.
If 235 is 12 fL then 17 is .004 fL and 16 is .00006 fL. (3K:1 and 200K:1)
I'm not sure how that would look but its has to be better than crushing your blacks by anchoring your gamma curve at .00006 fL.
Ken
KenLand is offline
post #23 of 845 Old 09-27-2005, 07:24 PM - Thread Starter
dokworm's Avatar
Liked: 25
Yeah we have touted an 'active backlight' a few times in these threads, and I have seen a product using and active backlight (not this one) and the effect is astoundingly good. I'd put money on this screen outperforming CRT monitors. You need to see this gear in person as the average digital camera can't record it.
Yup it is 50 grand, but people paid that for a plasma about that size only a few years ago, so it isn't out of reach to the high end guys.
Just on the camera issue, there is a bit of confusion here I think. The lux measurement isn't the cameras 'black level'.
The low lux measurement for the camera means that is the lowest level of light it can detect. If the light level drops below that then the camera 'see nothing' and records black.
i.e. it doesn't mean that if a camera is rated to 0.7lux and you record a completely black room (while sitting under a black velvet lead-lined blanket) that you get a recording of 0.7lux - you get pure black i.e. 16 for NTSC in the US, or 0 for the rest of the world (most cameras just record zero anyway and it gets stepped up to 16 later by an output device)
What is does mean is that any light in the room under .7lux will be recorded as absolute black, so if you had a bunch of very dark areas say .3 lux areas and .5lux areas and .6 lux areas you wouldn't see them in your recording - they would just all be black.
dokworm is offline
post #24 of 845 Old 09-27-2005, 07:34 PM - Thread Starter
dokworm's Avatar
Liked: 25
Plus you guys are missing a vital point, this is not an 8 bit display, so you are not stuck with the 16 to 235 steps (which is only valid for US NTSC anyway, as a monitor in 8bit you get 0-255)
You get a massive increase in bit depth with a display that can go higher than 8bit, so instead 256 available levels of R, G or B, in a 16 bit display you get 65,536 levels per RGB color channel.
i.e. instead of a 16,777,216 colourspace in 8bit per channel RGB, you get a 281,474,976,710,656 colourspace with 16bits per channel.
This is why film still tends to look so good, the colour depth far outshines any current CRT devices. It is also why in the film industry we work in at least 12bit colour when manipulating film digitally before recording it back to film again.
If anyone is interested in HDR stuff, there is a nice link page on their site.
http://www.brightsidetech.com/tech/resources.php
dokworm is offline
post #25 of 845 Old 09-27-2005, 08:21 PM
KenLand's Avatar
I would like to see this display and talk to them about calibration and setup.
No one said that the camera's minimum light sensitivity was its black level. Only that you don't want to waste too many levels between this and black, because the camera has recorded no, none, nada, zilch information at those levels.
Ken
KenLand is offline
post #26 of 845 Old 09-27-2005, 10:47 PM
Ohlson's Avatar
I am sure you know this but the leds in this monitor is far fewer than the lcd pixel resolution. I do not know or remember how mane led regions there are in this display. It works out well since our eyes tend to smooth things out. The boundary effects that I am sure are minimized by the technology is further reduced by our eyes.
Mattias Ohlson
Ohlson is offline
post #27 of 845 Old 09-28-2005, 12:47 AM
ChrisWiggles's Avatar
But presumably the source video is 8-bit, so it doesn't really matter that much what the bit depth of the display is as long as it's, what, basically 12bit for a linear display?
ChrisWiggles is offline
post #28 of 845 Old 09-28-2005, 12:56 AM - Thread Starter
dokworm's Avatar
Liked: 25
No, the source is not 8 bit, that is the whole point of one of these displays, they are for people who need to use HDR imagery.
Nothing to stop you talking to them Kenland, their number is on their website.
With a greater than 8bit display, the number of levels available are so huge, that the problem of the number of steps wasted between absolute black and the cameras lowest light register becomes a non-issue. There are plenty of increments left over in a 16bit per channel system :)
dokworm is offline
post #29 of 845 Old 09-28-2005, 01:01 AM
Well, then I guess I take that back, I figured it would be used with more standard video ;).
mmmm....16 bits per channel..... :)
post #30 of 845 Old 09-28-2005, 03:24 AM
KenLand's Avatar
Yeah, 16 bits per channel :)
Ken
KenLand is offline
Closed Thread CRT Projectors
