How do you post pics in thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-26-2006, 01:50 PM - Thread Starter
Ericglo's Avatar
Quoted: 855 Post(s)
Liked: 299
The thread in the sticky is gone. What happened?
Ericglo
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is offline
post #2 of 7 Old 01-26-2006, 02:19 PM
AVS Club Gold
Clarence's Avatar
Quoted: 160 Post(s)
Liked: 4103
Clarence is online now
post #3 of 7 Old 01-26-2006, 02:21 PM - Thread Starter
Ericglo's Avatar
Quoted: 855 Post(s)
Liked: 299
Click on the link.
Ericglo
Ericglo is offline
post #4 of 7 Old 01-26-2006, 02:32 PM
AVS Club Gold
MadMrH's Avatar
Yep your right its gone......
So what I do is this........
Take picture, resize to sensible size.
Host it on www.tinypic.com
then include a link in the post......
[img]http://tiny..........[/img ]
you need to remove the final spaceS prior to ]
http://i1.tinypic.com/mlqmpc.jpg
Borrowed from Rusty.........
Bringing Rodan-O-Blend to you.
Find me on the map :UK CRT : European CRT : Worldwide CRT
MadMrH is offline
post #5 of 7 Old 01-26-2006, 02:35 PM
AVS Club Gold
Clarence's Avatar
Quoted: 160 Post(s)
Liked: 4103
Weird.
Oh well, here's some of the same info...
Originally Posted by Kerncom
I would submit my WIP but I can never get my large digital shots to work on AVSforum. I think you are limited in file size and I can never get my shots down in size enough to post (I believe this is the case). If someone wants to clue me in on how to cut a 2 MB picture size down to post here I would love to hear from you!
I recommend the great freeware program from http://www.irfanview.com
Just select Image... Resize.
But if you don't want to install anything new, you can use the Microsoft Paint program (assuming you use Windows)...
Start... Programs... Accessories... Paint
Then open your original image:
File... Open...
Then reduce the image size:
Image... Stretch/Skew... enter a Horizontal and Vertical number of about 25%
(Let's assume you have a 3 megapixel or 4 megapixel camera which probably gives an original image of about 1500x2000... so if you want this to be 480x640, then you'd reduce to around 25%-30%)
http://img30.imageshack.us/img30/505/paintresize4za.gif
Then select the JPG file type:
Then upload your attachment to the forum.
Note that in order to see the attachment options, instead of Quick Reply, you'll need to click the "Post Reply" button at the bottom of the thread:
http://216.66.12.250/images/buttons-white/reply.gif
Even easier... upload your picture to http://imageshack.us, click the button that says "resize image to 480x640 for message boards", then post the link that they give you...
http://img5.imageshack.us/img5/236/imageshack8bc.png
if you put the link to the image between "img" tags, then the image will show up in your post...
[img]http://imageshack.us/yourimage.jpg[/img]
post #6 of 7 Old 01-26-2006, 02:39 PM - Thread Starter
Ericglo's Avatar
Quoted: 855 Post(s)
Liked: 299
What I was trying to find is the info for doing the little pics that you click to link to a big pic.
Ericglo
Ericglo is offline
post #7 of 7 Old 01-26-2006, 02:46 PM
AVS Club Gold
Clarence's Avatar
Quoted: 160 Post(s)
Liked: 4103
After you upload an image, imageshack will give you the thumbnail and url
Just copy the code they give you on the second page where it says
"Thumbnail for forums (1)"
But if you really want to know, the syntax is:
[url=http://server/bigimage.jpg][іmg]http://server/thumbnail.jpg[/img][/url]
I updated the sticky to point to this thread now.
Closed Thread CRT Projectors
taboola here
