Sony G90 Service Menu; What am I doing wrong? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-10-2000, 08:10 PM - Thread Starter
Chuck Williams's Avatar
Hey, G90 experts!
Isn't it "ENTER ENTER UP DOWN ENTER?" I can't get into a cuxtomer's service menu. The book says to make sure the remote is hard-wired, but I know that isn't required. The unit works fine otherwise, and the remote seems to function normally. What am I doing wrong?
Chuck
Video Electronics Specialist
Precision ISF Calibration
E-mail cmwtek@aol.com
Chuck Williams is offline
post #2 of 5 Old 07-11-2000, 06:10 AM
Tim McCune's Avatar
I was told by Roger Galvin that he never uses the remote in IR mode due to transmission errors. Given the long cord, I have never used it in IR mode either. I beleive you have the correct commands.
Tim McCune is offline
post #3 of 5 Old 07-11-2000, 08:57 AM
wm
wm's Avatar
Location: Spaceship Earth, usually on the California deck
Two words: STATUS ON
If "Status" is off, you can't get into service mode. It's a common problem, I was scratching my head when I got caught by this one...
IR mode works fine for me, as long as the batteries are fresh. With older Sony's where you had to hold the button for 5-6 seconds to get into service mode, IR was nearly impossible.
William
wm_avs6 (at) meier-phelps (dot) com (Note - new address! Please do not use AVS PM)
Optimized by William PhelpsÂ
wm is offline
post #4 of 5 Old 07-11-2000, 02:37 PM
Gary S's Avatar
Quoted: 25 Post(s)
Chuck-William's exactly right (of course). I pushed Enter Enter Up Down Enter so many times I thought my fingers were going to bleed until I stumbled across the Status button trick!
Gary S is offline
post #5 of 5 Old 07-11-2000, 04:16 PM - Thread Starter
Thanks, guys! I knew it had to be something easy. I've never had a problem just doing it IR, either.
Chuck
Closed Thread CRT Projectors
