Small Squiggly interference lines on NEC XG 1352 ?? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #271 of 284 Old 09-03-2006, 10:53 AM
Quoted: 40 Post(s)
Oh you are getting VP 50? What are you going to do with your VP30?
It is all about quality. That is the picture.
JVC DLA-RS20, NEC XG-1352LC 8" CRT, 106" wide StudioTek 130 screen
CaspianM is offline
post #272 of 284 Old 09-03-2006, 12:25 PM - Thread Starter
Gary Murrell's Avatar
thanks Moe I sent you a PM
I had multiple people offering me Studioteks and I will be damned if it didn't happen in a situation where I couldn't use them, I have always wanted a studiotek, in this new room space is such a premieum that I could only use 2.35:1 sized screen, which I wanted to try anyway
not sure what I will do with the VP30 at this time
I will prolly sell it
-Gary
Gary Murrell is offline
post #273 of 284 Old 09-10-2006, 02:50 PM - Thread Starter
my quest is over
I have installed my new tube, calibrated for 2 days and can officially say the 1352 is not going anywhere anytime soon
I installed my new OEM green, and preceeded to use 1920x800p for my setup being that my screen is 2.40:1, so I am getting exactly the same resolution that 16:9 screens have when showing 2.40:1 movies which is 800 lines P, 1920x800p destroys 1080i and I have my bud Craig R to thank for that, I would have never thought to do that, thanks Craig I woe you one dude ;)
1920x800p hit the spot on the NEC and like I said, it is the same as 1080p at 16:9 but is not as hard on the PJ of course and is under the bandwidth spec
my 1:1 1920x800p pattern is clearly visible in all 4 corners and center and can be seen in center from my viewing distance, which is amazing :eek:
so I am displaying 1920x1080i 2.40:1 movies(which only have 800 lines of resolution) 100% unscaled and progressive, oh my oh my, with my 2.35:1 setup I have no need at this time to look at a 9" CRT, the NEC 1352 is that wicked
uping the resolution also seemed to tame the interference lines ALOT and I removed the fan from the green neck card which seemed to help even more, not a issue anymore :)
like I said my quest is over, time to enjoy my labor, I won't be online as much anymore because I have my HT back now :)
thanks for all the help guys and again thanks Craig for the tip
I will have more to say tomorrow about my setup(scaler etc.) and process so stay tuned, I wish someone could see this though, talk about unreal pix quality :eek:
-Gary
post #274 of 284 Old 09-10-2006, 06:19 PM
JMSE's Avatar
Gary, I'm glad to hear that new tube worked out for you.
Jim
JMSE is offline
post #275 of 284 Old 09-10-2006, 06:48 PM - Thread Starter
thanks Jim, I appreciate the good deal dude, thanks ;)
-Gary
post #276 of 284 Old 09-10-2006, 09:04 PM
benny's Avatar
Originally Posted by Gary Murrell
my quest is over
-Gary
Well done Gary !
Good to hear it's all come together at last. I can understand the journey might have been a little frustrating but its completed now and time to relax, watch movies and have a few beers :) Quite often though, the journey can be just as enjoyable as the destination.
It's also reassuring to hear you discovered, as I did, that running higher vertical resolutions helps to negate the video noise issues, and that you've chosen to run progressive rather than the inferior interlaced alternative ( cue Mark ... stage left LOL ).
Your wish has been granted as I can envisage what you are seeing now .... I experience it everytime I switch mine on :D
Cheers and happy viewing :)
Russ
It's converged! Now if only I could remember what I did ......
benny is offline
post #277 of 284 Old 09-10-2006, 11:19 PM - Thread Starter
it just ain't meant to be guys :mad:
I finally sat down to watch a movie after 4 months, half way in the middle pop, the screen sucks in and back out, the center of all 3 tubes lost em focus, the outer is the same, the outer focus controls have no effect on any tube, the center has to be adjusted to 100% and that doesn't even fix it nor does the pot fix focus as it cannot be dialed enough
I guess this just isn't meant to be guys :(
-Gary
post #278 of 284 Old 09-10-2006, 11:31 PM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
-Gary
I've said that a couple times myself over the last couple years, Gary. Then I fixed the problem(s) and moved on. :)
SUCKS to have happen though. Especially after you were in heaven just a few minutes earlier.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #279 of 284 Old 09-10-2006, 11:53 PM - Thread Starter
thanks for the comfort Eddie, I might need to look elsewhere though, this NEC 1352 has been nothing but trouble, problem after problem
I am thinking maybe to part him out and move on at this point in time, the image from this thing was so nice though, I will need a serious PJ to top it
who knows :(
-Gary
post #280 of 284 Old 09-11-2006, 04:23 AM
Doug Baisey's Avatar
Location: Diamond Bar Calif USA 91765 / Seattle area WA 98512
Gary,
I dont think I would have removed the green neck board fan but would have found out why. Could have been mounted wrong or defective.
Posted in your new thread about the focus. Doug
http://www.avsforum.com/avs-vb/showthread.php?t=722024
Doug Baisey is offline
post #281 of 284 Old 09-11-2006, 08:59 AM
Quoted: 40 Post(s)
Unfuc*%^& believable gary. Be patient you'll be aright!
CaspianM is offline
post #282 of 284 Old 09-11-2006, 11:31 AM - Thread Starter
Doug I will reconnect the Fan
why does the green have a fan and the other 2 don't ? weird
-Gary
post #283 of 284 Old 09-11-2006, 03:58 PM
Mark_A_W's Avatar
Because the green works harder and the other 2 are right next to the side fans.
Loving my Electric Bike!!
Mark_A_W is offline
post #284 of 284 Old 09-11-2006, 04:59 PM - Thread Starter
makes sense :)
-Gary
Closed Thread CRT Projectors
