Edge Blending: Cheaper by the dozen - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 367 Old 02-12-2010, 05:39 PM
Sinobi's Avatar
Originally Posted by benwillcox View Post
Interesting, the last version I tested was something like 1.0, and that version had a bug that meant that with panoramix enabled no video actually displayed except for a few frames every few seconds. It seems to be working better in 1.0.3 that I have just downloaded! However, it still seems to be broken compared to the 0.9.0 SVN version from August 2008 that I have been using for the last year or so.
I had some success just now with this 1.0.3 version, but the crop module seems to have a problem with some material depending on the source aspect ratio. So sometimes it works, sometimes it doesn't.
I'll be sticking with the 0.9.0 version though for now, as there is still definately something wrong with the latest version with some video files.
Ben
Actually I have just been playing around with the latest VLC version (1.05) and it seems to work properly now.
Finally, after using a crippled for years now, we now have a version that works.
Hopefully someone will make the advanced functions of the blendzone work in the panoramix module, so we can have a perfect blend.
EDIT: The automatic cropping function does not work in 1.05. Upon a new aspect ratio detection the program exits. If you instead set aspect ratio manually in the crop module, it works fine.
Regards
Henrik
More Pixels To The People!
Stereo......is about projectors. The Soooooony 12" CRT owner.
Sinobi is offline
post #362 of 367 Old 08-15-2010, 02:35 PM
Sisyphus's Avatar
Sisyphus is offline
post #363 of 367 Old 08-17-2010, 03:38 AM
MadMrH's Avatar
Hi,
I contacted Mviewtech.com
here are a couple of links about the product
"The video demo at http://v.ku6.com/show/wSmElYAISRMsnsJZ.html
And I place some picture at http://www.widescreengamingforum.com/forum/viewtopic.php?f=78&t=18394"
video above is office testing on wall - looks "ok"
pictures in the forum link show FULL red / green / blue , and the images appear to have no "stepping" within the blend zone.
The unit is NOT HDCP compliant and so designed for PC games.
I downloaded the manual for the 2 ch unit (they also have a 3ch version)
blend zone from 0 to 512 pixels, very basic single page for setup, so easy to use - I dont know what it actually looks like in real life!
At its current price I will not be getting one in for testing.
(Does anyone know an available HDCP removal device ??? - PM ME)
PS - I need to find some time and find/check an old PC hard drive, when I started blending I listed every possible option available and those not yet on market with as much detail as I could find, I would like to find that document and post for all, a sort of history of blending.
Andy.
Bringing Rodan-O-Blend to you.
Find me on the map :UK CRT : European CRT : Worldwide CRT
MadMrH is offline
post #364 of 367 Old 08-18-2010, 04:30 AM
atlemusic's Avatar
Hi!
A fast question, if i use a videocard with two DVI out and put the Media Player Classic to Fullscreen. Can i use it to blend two CRT projectors with Moome?
atlemusic is offline
post #365 of 367 Old 08-18-2010, 05:09 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Yes you can. I use the Tv-One units.
Athanasios
nashou66 is offline
post #366 of 367 Old 08-18-2010, 04:55 PM
dvh99's Avatar
does he not need a shader plugin for the luminance roll off?
dvh99 is offline
post #367 of 367 Old 08-20-2010, 04:15 AM
atlemusic's Avatar
shader plugin? hmm sounds like a good feature!
Reply CRT Projectors
