Need some help as I just got a Vidikron Vision One - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 134 Old 06-27-2007, 12:14 PM
madpoet's Avatar
Quoted: 20 Post(s)
Liked: 25
Why did you revive a 3 month dead thread?
Someday maybe I'll actually WATCH my projector...
madpoet is offline
post #122 of 134 Old 06-27-2007, 12:17 PM
oliverg's Avatar
I'll swap it for a Sony Ruby (or a Pearl) or even 2
Its a much better digital technology - I'll even throw in 20 spare globes.
And set it up for you. Deal?
My goal: A blend of double stacked G90s! Encased in ice to prevent drift.
oliverg is offline
post #123 of 134 Old 06-28-2007, 06:33 AM - Thread Starter
whowillbe's Avatar
you serious??? Well I can take 2 JVC RS1 instead...
whowillbe is offline
post #124 of 134 Old 01-05-2008, 05:56 AM - Thread Starter
whowillbe's Avatar
yes...
post #125 of 134 Old 01-06-2008, 05:55 AM - Thread Starter
whowillbe's Avatar
it was updated in another thread. yup its been running strong for the past year.
post #126 of 134 Old 01-06-2008, 08:47 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
I'm making a HUGE assumption here, but if whowillbe got his set from the same place that I bought a couple of surplus sets from overseas, they needed MASSIVE amounts of work to get them going. I got two Visions from overseas and both had glycol leaks which toasted a bunch of stuff. One of the chassis had super low hours on it, but still.
I don't know why these sets had all of these problems. My suspicion was that the dealer used these sets as parts mules for others in the field, and put a bunch of bad boards from the field into the two units I got. That still doesn't explain the glycol leaks.
Once they were all cleaned up though, they ran fine and I sold them.
www.curtpalme.com - CRT tech info
www.soundsolutionscanada.com -pro audio website
Curt Palme is offline
post #127 of 134 Old 01-06-2008, 03:25 PM
donaldk's Avatar
Quoted: 498 Post(s)
Liked: 122
The companion pair to the the two that went to Holland, Curt? Those two were clean I believe, but still were completely rebuild. The first one is now sold, but the second one is still awaiting a buyer, I believe. They fitted wear free PLUGs in the machine.
donaldk is offline
post #128 of 134 Old 01-06-2008, 03:28 PM
Mark_A_W's Avatar
Originally Posted by reio-ta View Post
Seems your assumption was correct!
I'm thinking of getting an LC set too, the NEC 1352. How do you make sure you don't have the glycol spill out? At the same time I don't want too little and have the tube implode. I read a thread on your site about a guy with an LC set and the glycol and glycerin mixture became too low. Would that ever make me mad!
I've never heard of a stock NEC tube leaking in a set (Curt may have), closest is a VDC tube leaking for Don Kellogg.
Loving my Electric Bike!!
Mark_A_W is offline
post #129 of 134 Old 01-06-2008, 04:59 PM
draganm's Avatar
Quoted: 21 Post(s)
Originally Posted by Curt Palme View Post
I'm making a HUGE assumption here, but if whowillbe got his set from the same place that I bought a couple of surplus sets from overseas, they needed MASSIVE amounts of work to get them going. I got two Visions from overseas and both had glycol leaks which toasted a bunch of stuff. One of the chassis had super low hours on it, but still.I don't know why these sets had all of these problems. My suspicion was that the dealer used these sets as parts mules for others in the field, and put a bunch of bad boards from the field into the two units I got. That still doesn't explain the glycol leaks.
Yes, whowillbe's machine came from that same place. The reason they were so trashed is as you suspected, these were parts mules. I'm pretty sure the owner was shocked at what you guys wound up paying for the machines. I looked into it but the $1700. in freight alone was enough to scare me off. Also, singapore has like 90% average humidity, and that is REALLY bad for the LC chambers in a CRT as they absorb a lot pf mosture and swell, eventually causing a leak.
whowillbe, it's really good to hear your 9500 is now solid. I would recomend removing one of the drain screws on each tube and letting the excess pressure blead off.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #130 of 134 Old 01-06-2008, 08:03 PM - Thread Starter
whowillbe's Avatar
Yes I believe there were from the same place... well I believe that Curt and Dragamn were both right, that the shop used those projectors as spare parts in fact, when the Vision One started developing problems, they weren't able to provide the support they were supposed to as the 2 projectors were shipped overseas... guess I deserved it then....
Anyway after reading on this forum, and tinkering around with the projector, I've found that the Marquee is a really easy machine to work...
Draganm, I've already loosen the screw to release the excess pressure after I found glycol leaking out of the chassis and I also readjusted my projector as recommended by your guys earlier in the thread and you all were so right, the image were better.
post #131 of 134 Old 10-09-2008, 09:10 PM
Mark_A_W's Avatar
Ok, why are we feeding a Vision 1 a DVD signal in this day and age???
Mark_A_W is offline
post #132 of 134 Old 10-21-2008, 12:55 AM
tekkentoh's Avatar
Hi Whowillbe,
I think I can solve your Vidikron Vision One's problems.
I have all the spare parts and solved similar problems before.
Please contact me if you need any help or advice. Please use my previous email to contact me.
Proceed Avp2+6 pre/pro
Proceed AMP3 power X2
proceed PMDT cd/DVD transport
Oppo 95 bluray player
Jvc RS25 dila projector
Marquee 9500 Crt. Projector
Darbee darblet
tekkentoh is offline
post #133 of 134 Old 12-31-2013, 12:01 PM
benjaminys1's Avatar
Hi does anyone know the service code for a vidikron 90t
benjaminys1 is offline
post #134 of 134 Old 01-01-2014, 07:38 AM
Curt Palme's Avatar
Quoted: 34 Post(s)
Liked: 61
you'll have more luck posting in the digital forums, this is the CRT forum. Otherwise you may need to call Runco, who may or may not be helpful.
Reply CRT Projectors
