Ok Folks! Show me your dots! - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #271 of 283 Old 10-26-2006, 02:56 AM
Mark_A_W's Avatar
I don't get the big deal either Oliver.
None of my XG's really lose focus until the high nineties - you'd barely notice it on a grid.
Loving my Electric Bike!!
Mark_A_W is offline
post #272 of 283 Old 10-26-2006, 08:36 AM
cmjohnson's Avatar
Quoted: 28 Post(s)
For a Marquee, this is a very signficant improvement. To be absolutely honest
about it, the Thomson focus magnetics used in Marquee are....well, they suck. OK? They SUCK.
I believe that NECs use yokes made by Kanto Denshi, which is what I've started putting
into Marquees...but I do some modifications. It's necessary in order for them to run in
a Marquee and deliver their best performance.
The K-D magnetic focusing system is unquestionably superior. No doubt about it.
CJ
cmjohnson is offline
post #273 of 283 Old 10-28-2006, 07:26 PM
mrking's Avatar
Wow. LOOONG thread.
I am really impressed how much swapping out the focus coils in a marquee did to the difference of the beam size at 40 and 100 in contrast!
This is without a doubt the worst part with the Marquee series in my opinion. At least if you like having a BIG screen. You simply can't get enough light output out of the marquee without having the picture bloom like crazy. Especially the blue tube. If these frankenyokes reduces that problem to this extent then I must commend Chris for a job well done in discovering this.
Maybe this is why people insist on running such small screens on this forum. They can't run any bigger without blooming all to hell. ;)
I'm running my 9500LC at 11ft wide right now though... in an absolutely light controlled room. The walls in my theatre is covered with black out cloth everywhere. =)
"Once you go BLACK you never go BACK!.." CRT forever!!!
info at cimagine.se
mrking is offline
post #274 of 283 Old 12-28-2006, 12:08 PM
kschmit2's Avatar
kschmit2 is offline
post #275 of 283 Old 12-29-2006, 02:32 AM
Oliver Klohs's Avatar
Quoted: 40 Post(s)
Kai,
these look very good - you ware ready for 1080p 48 I see :)
Oliver
Oliver Klohs is offline
post #276 of 283 Old 12-29-2006, 02:50 AM
kschmit2's Avatar
At my current throw distance I cannot get the image wide enough at 1080p48 (despite tweaking the timings).
So I'll just live with 1080i96 :)
kschmit2 is offline
post #277 of 283 Old 12-29-2006, 03:46 AM
Mark_A_W's Avatar
I would have thought they would be the same (?).
Bandwidth is the same. Scanrate is the same...how is it different?
1080i 96hz is a better res than 1080p 48 anyway ;)
Mark_A_W is offline
post #278 of 283 Old 12-29-2006, 04:37 PM
Quoted: 40 Post(s)
My thoughts exactly, the first part that is :)
Somebody has got to carry on the interlaced vs 48 Hz debate ;)
post #279 of 283 Old 12-30-2006, 02:15 AM
kschmit2's Avatar
many PJs use different modes when processing interlaced vs. progressive signals. I assume the same is true for NECs.
Bandwidth and scanrate are of course identical though.
kschmit2 is offline
post #280 of 283 Old 12-30-2006, 04:59 AM
Quoted: 40 Post(s)
At least you do not need to worry about HD deinterlacing :)
post #281 of 283 Old 12-30-2006, 05:29 AM
kschmit2's Avatar
I only watch stuff after IVTC (film sourced stuff) using 1080i96.
So the source provides progressive sequences at 23.976 frames per second. These get re-interlaced for output at 95.904 fields per second.
kschmit2 is offline
post #282 of 283 Old 12-30-2006, 05:55 AM
stefuel's Avatar
Quoted: 27 Post(s)
Liked: 24
You gotta love those PG plus's. Very under rated PJ. I have a 9 PG Plus with brand new (factory, not rebuilt) tubes in storage that I would not hesitate to put back up in place of my 4600HD. The only problem is that the tubes would wear much faster than a 9" tube. The highest rez I ever tried on it was 1440X960P via PC and it did it no problem. I did not have a scaler at that time that did that though so I stuck with 720P.
Chip
Current owner of the last/best AmPro on the planet. The mighty 4600HD, and it's still running...better than Barco's, especially southern ones.
stefuel is offline
post #283 of 283 Old 12-30-2006, 07:50 AM
Doug Baisey's Avatar
Location: Diamond Bar Calif USA 91765 / Seattle area WA 98512
With the processing and scalers we have now it really opens up what you can actually do with the Plus and Extra. It may or may not require a new mechanical set up but what the heck.
Nice job kschmit2! Looks really good. Doug
Doug Baisey is offline
Closed Thread CRT Projectors
