ECP - Green flicker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-05-2006, 03:01 PM - Thread Starter
MrGogo's Avatar
Hi guys ... got a problem
The green tube on my ECP 4000 flickers horizontal bands. The effect is that my picture turns a bit purpleish like the green isn't being driven as hard as it needs to be. It never stop displaying the picture completely its just gets dimmer in stripes across the screen. Sometimes its the whole tube face some times its horizontal bands that jump around. And the most annoying thing is that its very intermitant. Its will work fine for 30min then flicker like crazy for 2min then back to normal.
What I've done so far:
- Checked the input wires from my HTPC ... its good I wiggled the hell out of it and nothing happened.
- Removed the neckcard from the green and put it back on.
- Disconnected every wire from the G2 control to the neckcard and reseated them.
- Pulled all the circuit boards out of the back and reseated them
To do:
- Recheck connectors on green neck card.
- Pull power deflection module and reseat it (I don't think that could be it though)
Anyways crealy its some sort of loose connection along the signal path that intermitantly getting woozy any ideas where else I can fiddle. If any can thing of a spot where these connectios go bad that I haven't let me know.
Tnx for the help.
MrGogo is offline
post #2 of 7 Old 12-05-2006, 03:28 PM
Qwal_will's Avatar
I am no expert on these so can take this with a grain of salt
When I was adjusting my ECP 3100 I would get these strange flickering as well. What solved it for me was on the CRT socket the trim pots on the back of it were very touchy. I got some cleaner / lubricant and sprayed them. Worked the cleaner / lubricant in and then did the setup again. Has not given me issue since.
Again this may not work for you but did work for me.
Cheers,
Shawn
Qwal_will is offline
post #3 of 7 Old 12-06-2006, 09:14 PM - Thread Starter
MrGogo's Avatar
Bump,
Any other ideas from the experts?
MrGogo is offline
post #4 of 7 Old 12-06-2006, 10:57 PM
pcCinema's Avatar
Swap the green neck board with blue or red and see if the problem moves to the other color. If so you need a new neckboard. I'll bet that's all it is.
Troy
The Non-Profit Home Theater Company will make your HTPC experience much easier.
Link for info on our first project
pcCinema is offline
post #5 of 7 Old 01-28-2007, 07:46 PM - Thread Starter
MrGogo's Avatar
Hey guys, thought I had fixed this but nope.
I replaced the neckboard on the green tube with one that I know works from another set. Didn't fix it, damn.
This is really starting to piss me off.
I have a full set of parts but I don't know what to swap.
Any suggestions?
MrGogo is offline
post #6 of 7 Old 01-28-2007, 08:46 PM
Soapsuds's Avatar
swap the grn RGBHV for another colour. If the problem moves with the cable, it's something in the HTPC chain. At least this will help narrow it down....
Soapsuds is offline
post #7 of 7 Old 01-29-2007, 05:00 PM - Thread Starter
MrGogo's Avatar
Good call Soap.
But it affects the convergence grid too. I suppose it might be that I'll give it a try.
Thnx any one else with suggestions?
MrGogo is offline
Reply CRT Projectors
