Newb question Electrichome-8500 and Snyc issue. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-07-2007, 09:06 AM - Thread Starter
Noobnewb's Avatar
Thanks figured it out.
Noobnewb is offline
post #2 of 3 Old 01-07-2007, 10:22 AM
draganm's Avatar
Quoted: 21 Post(s)
2011 is not high hours, machines are rated for 100,000 hours and set of tubes for 10,000. hours. The projector only takes RGB= red, green, blue, vertucal, and horizontal, not component from a typical DVD player.
for value's you can check www.videogon.com. They gave you about $2000. worth of projecotors.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
post #3 of 3 Old 01-07-2007, 01:40 PM - Thread Starter
Noobnewb's Avatar
Thanks for the help.
Noobnewb is offline
Reply CRT Projectors
