How to change image size independent of raster size on an XG? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-15-2007, 04:24 AM - Thread Starter
Dan Ellis's Avatar
Is there any way to change the image size without changing the raster size on an XG1352? It doesn't make sense to me why this would not be adjustable. I would like the ability to shift the image vertically within the raster, but as it is the raster is almost completely filled with the image vertically, so there is little room for movement.
Dan Ellis is offline
post #2 of 9 Old 01-15-2007, 09:12 AM
garyfritz's Avatar
The size and position of the image within the raster are not controlled by the projector, but by the source. The projector just displays the entire raster and whatever's in it. The source determines the image size/placement within the raster via the porches. Larger porches = more "margin" around the image = smaller image.
garyfritz is offline
post #3 of 9 Old 01-15-2007, 09:22 AM - Thread Starter
Dan Ellis's Avatar
I have noticed the reference to "porches" on some threads, but it seems to be an HTPC term. What if the source is directly from a digital cable box? Do the newer high end processors provide the equivalent of the porche adjustment?
post #4 of 9 Old 01-15-2007, 09:43 AM
Quoted: 40 Post(s)
Why do need to change the size? Changing the original size of an image from the source is altering its resolution. I don't even like to mess with porches as it resizes the image.
It is all about quality. That is the picture.
JVC DLA-RS20, NEC XG-1352LC 8" CRT, 106" wide StudioTek 130 screen
CaspianM is offline
post #5 of 9 Old 01-15-2007, 09:54 AM
Ile
Ile's Avatar
Too small porches cause vertical bars to raster/picture, too big porches soften picture and stress horizontal deflection with big resolutions.
Ile is offline
post #6 of 9 Old 01-15-2007, 10:19 AM
Doug Baisey's Avatar
Location: Diamond Bar Calif USA 91765 / Seattle area WA 98512
You have position (shift) to move V in the raster until it runs out of area then will cause a 'whip' retrace line if you go to far. Check to see if blanking is backed out also. Doug
Doug Baisey is offline
post #7 of 9 Old 01-15-2007, 11:59 AM
deronmoped's Avatar
Decreasing the porches is like increasing the bandwidth of the PJ. The PJ is drawing the whole raster no matter what and it takes time to do this. Why have the PJ waste precious time drawing something that you will not see, this leaves less time to draw the image.
That is one big reason to have a HTPC, controll over the image: porches, refresh rate, gamma...
Deron.
Deron.
CRT Videophile
deronmoped is offline
post #8 of 9 Old 01-15-2007, 12:28 PM
ThomasW's Avatar
A videoprocessor like Lumagen or DVDO will do the job too. Maybe more expensive than a HTPC, but also much more reliable than a computer in being a dedicated device.
Thomas
ThomasW is offline
post #9 of 9 Old 01-15-2007, 12:36 PM
garyfritz's Avatar
!? Changing the porches does nothing to the image resolution. It just changes the amount of "dead air" time before/after the image. It will change the size of the image within the raster, but it doesn't change the image itself.
Now if you use a processor to change the porches, I suppose it's possible the processor might rescale or otherwise muck with the picture. But you can change the porches without touching the resolution of the image.
Reply CRT Projectors
