Resistors on NEC C Drive - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-15-2007, 06:19 PM - Thread Starter
GlenF's Avatar
Do the 3 watt 1.8ohm resistors have to be replaced with exact counterparts?
I can get 5watt 1.5ohm or 5watt 2.2 ohm but can't find 3 Watt 1.8 ohm ones.
GlenF is offline
post #2 of 9 Old 01-15-2007, 06:45 PM
tse
tse's Avatar
http://www.mouser.com/search/Product...lkey283-1.8-RC
Mouser part number 283-1.8-RC
No minimum order.
Scott
tse is offline
post #3 of 9 Old 01-15-2007, 07:39 PM
Doug Baisey's Avatar
Location: Diamond Bar Calif USA 91765 / Seattle area WA 98512
Thanks Scott, Doug
Doug Baisey is offline
post #4 of 9 Old 01-15-2007, 08:48 PM
Mark_A_W's Avatar
Glen, I got some locally from Farnell. Still cost more for the shipping than the part..
Loving my Electric Bike!!
Mark_A_W is offline
post #5 of 9 Old 01-15-2007, 08:55 PM
dokworm's Avatar
Liked: 25
I have some Glen, how many did you want?
DON'T feed the troll.
dokworm is offline
post #6 of 9 Old 01-16-2007, 07:31 PM
dokworm's Avatar
Liked: 25
If you want a few then you can order them here:
http://au.farnell.com/jsp/endecaSear...lts&sku=343705
dokworm is offline
post #7 of 9 Old 01-16-2007, 07:43 PM - Thread Starter
GlenF's Avatar
So they might have the 470 ohm capacitor for the Deflection Board as well?
How do I know which is the low ripple ones in their catalog?
GlenF is offline
post #8 of 9 Old 01-17-2007, 04:45 AM
Mark_A_W's Avatar
They definitely have 330uf, which will do. Panasonic Low ESR/High Ripple.
I have an original Rubycon 470uf kicking around, if you get desperate, but it's old and unused, and would need reconditioning (google).
Mark_A_W is offline
post #9 of 9 Old 01-17-2007, 03:37 PM - Thread Starter
GlenF's Avatar
I think I will buy a new one, I was just confused as to the ripple numbers they quote on that site. I am not sure what constitutes high ripple vs low ripple.
GlenF is offline
Reply CRT Projectors
