Xbox experts! Anybody know how to get HD output from XBOX to CRT? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-13-2007, 09:29 PM - Thread Starter
mcastleberg's Avatar
I play Xbox on my Marquee 8500 all the time (original xbox mind you, not 360). I connect the xbox to my Onkyo receiver and from that I run an RCA to my DVDO iScan progressive scan interface which is connected to my 8500. I'm not sure what resolution the Xbox outputs with the regular A/V cables but I'm guessing its probably 480i or something. If I were to get the HD cables for the Xbox and run those directly to the iScan, would I get a significantly better picture?
mcastleberg is offline
post #2 of 13 Old 02-13-2007, 11:14 PM
dokworm's Avatar
Liked: 25
Yes you get a massively better picture, 480P at least, and some games in 720P and a very few (like Dragon's Lair) in 1080i.
If you have modded your xbox then you can use Xbox Media Centre to playback movies, divx, DVDs, photos etc. at 1080i, 720P or 480P.
DON'T feed the troll.
dokworm is offline
post #3 of 13 Old 02-14-2007, 07:18 AM - Thread Starter
hell yes my xbox is modded! i never stopped to think about that HD cable until i was browsing xbox accessories on ebay the other day, which brings me to my next question. there are a bunch of cheap-o off-brand xbox hd cables on ebay, does it matter what brand i get? will the cheap knockoffs work as well as the Monster or Microsoft branded cables?
post #4 of 13 Old 02-14-2007, 07:27 AM
budiman's Avatar
I don't know enough about the 8500 that you have, but the original XBox only have Component HD output; Microsoft never came out with an RGB cable. So, if you Marquee only accepts RGB, you have to use a reverse transcoder.
Any accessory for the XBox that outputs RGB (as far as I know) basically become cheap transcoder from component to RGB. If someone can tell me I'm wrong, I'd be happy .
Ciao.
Muljadi Budiman
budiman is offline
post #5 of 13 Old 02-14-2007, 07:35 AM - Thread Starter
good point. the hd cables i've seen on ebay are component like these http://************/1a4wk
so how exactly do i go about getting high resolution output from my xbox to my 8500? i don't know much about transcoders obviously.
doesn't my iScan progressive scan interface upscale the signal or something? what purpose does that serve other than basically having the BNC connectors that my Marquee takes?
post #6 of 13 Old 02-14-2007, 07:56 AM
mrking's Avatar
http://www.x2vga.com/
"Once you go BLACK you never go BACK!.." CRT forever!!!
info at cimagine.se
mrking is offline
post #7 of 13 Old 02-14-2007, 08:42 AM
klover's Avatar
Buy the Microsoft VGA cable and a $2 coupler. Attach that to a VGA-BNC5 breakout cable.
Done.
klover is offline
post #8 of 13 Old 02-14-2007, 09:04 AM - Thread Starter
Done.
By "Microsoft VGA cable" do you mean the HD component cable for the xbox? What about the $2 coupler? What exactly is that?
post #9 of 13 Old 02-14-2007, 09:50 AM
garyfritz's Avatar
That X2VGA transcoder will transcode the component output to 1080p for *games*. But DVD / HD-DVD content is limited to 480p over component. For 1080i/p DVDs you need to pull your RGB off the VGA connector.
That's the way the Xbox 360 works, anyway...
garyfritz is offline
post #10 of 13 Old 02-14-2007, 09:59 AM
John Alison's Avatar
Have a look at the xbox360 web site - the cables are listed. As klover suggests, use the MS VGA cable to give you RGBHV on a standard D-type connector which can then be broken out into coaxial cables to your PJ.
The 8500 should be happy with the video timings from the XBOX. I usually shove things into a dektop CRT monitor first just to check everything is sensible.
John Alison is offline
post #11 of 13 Old 02-14-2007, 10:06 AM
klover's Avatar
Sorry, here's the link to the VGA cable.
http://www.xbox.com/en-US/hardware/x/xbox360vgahdcable/
Oh, and the coupler is included with the cable (it allows you to connect the Xbox 360 VGA end to another VGA end - the one from the breakout cable that is attached to your projector).
Cheap and works great.
klover is offline
post #12 of 13 Old 02-14-2007, 10:49 AM
fuzzy bee's Avatar
He's looking for the original XBOX.
fuzzy bee is offline
post #13 of 13 Old 02-14-2007, 03:46 PM
dokworm's Avatar
Liked: 25
I assumed the ISCAN had component inputs and you would run the HD cable straight into that.
If it doesn't have component inputs then you will need either the Crescendo Systems RC2200 or the X2VGA box.
I get the actual MS HD cable if you can, it is pretty good quality. The cheapos probably work OK though.
You can flash the bios of the xbox to put out a true VGA signal directly, but some games don't work and MAME doesn't work either, so that was the deal breaker for me.
dokworm is offline
Reply CRT Projectors
