Component Input Card for Marquee? - AVS | Home Theater Discussions And Reviews
Old 05-12-2007, 11:19 AM - Thread Starter
Tim in Phoenix's Avatar
Guys!
I have not followed this closely, who has the best one? It would likely get fed from a Toshiba HD player.
Tim at E-Tech ooo ehometech@earthlink.net ......your Marquee Pro Shop!
Tim in Phoenix is offline
Old 05-12-2007, 11:22 AM
nashou66's Avatar
Quoted: 85 Post(s)
Liked: 98
The only one i know of is the one Moome makes, the older DVI modle has component also and the new card comming out will also have component. And i know VDC has a HD modual for the marquee but not sure what that is i have sent e-mails to them asking but havent gotten a responce.
Athansios
nashou66 is online now
Old 05-12-2007, 11:29 AM - Thread Starter
Athansios
The Electrohome HD board is RGB and tri-level sync for a few broadcast tape machines and is likely obsolete at this point.
Old 05-12-2007, 11:48 AM
AVS Club Gold
madpoet's Avatar
Yep, your only choice is Moome's board or getting a transcoder like Kim's.
Someday maybe I'll actually WATCH my projector...
madpoet is offline
Old 05-12-2007, 11:51 AM - Thread Starter
Hello
Which one had power issues if installed wrong? Will component go over a 25 foot cable run OK?
Old 05-12-2007, 11:56 AM
nashou66's Avatar
Quoted: 85 Post(s)
Liked: 98
I used component at 25 feet to a digital before i went crt and that worked fine.
Atanasios
Old 05-13-2007, 06:52 AM
mark haflich's Avatar
Quoted: 1080 Post(s)
Liked: 769
Just make sure the 3 wires comprising the component run are all the same length.
Mark Haflich
markhaflich@yahoo.com
call me at: 240 876 2536
mark haflich is online now
Old 05-13-2007, 07:02 AM
Jim Kildare's Avatar
I have Moome's original DVI / component card with 25' component cable and it works fine. My Blu ray will only allow 720p over component, so I output 1080p via HDMI>DVI. (cables are blue jeans)
Moome's new card, HDMI / component is due out in a couple of weeks and has optional gamma control and an optional remote. (HDMI 1.2)
Jim Kildare is offline
Old 05-14-2007, 08:51 AM
draganm's Avatar
couple of weeks? It's been due out now for 3 months I love his card but there's a serious supply problem with his stuff.
Tim, Dave Babbit has one on his 8500 if you want to check it out. He's moved from Bell Road down to Surprise but the loop should get you there in 30 minutes. It looked pretty good to me with a DVI cable feeding HDTV but I thought up-scaled RGB from HTPC looked a little better. This was with the old Moome card, the new one is supposed to have a better chip and be able to take HDMI directly.
Marquee HD mod's Marquee Upgrade/re-build package
draganm is offline
