Infocus X1 dust problem, not on lens - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-20-2007, 06:54 PM - Thread Starter
Danpowered's Avatar
I just moved to my new place, and i had to take my infocus of its mount (its been there 2 years). I cleaned the dust filters beside the lamp often, to be sure they werent clogged with cat hair and stuff.
Now i just mounted it back on the ceiling. The thing is, now there seems to be some kind of "stain" outside of the image while projecting in 16:9, and when i take my projector close to a wall, i can see dozens of white dots on the projection (see picture).
Now i used a compressed air can to try and remove the dust but it doesnt do any good. Is there something i can do except take it to the service center (and pay a hell of a lot more that i accept to pay for a 4 years old projector)?
i didnt open the projector box, or anything like that yet.
Thanks for any help you can give, this is about the only place i can find that i could find any answer.
Danpowered is offline
post #2 of 4 Old 05-20-2007, 07:13 PM
NautikaL's Avatar
NautikaL is offline
post #3 of 4 Old 05-20-2007, 09:52 PM
ChrisWiggles's Avatar
Great excuse to upgrade projectors!
ChrisWiggles is offline
post #4 of 4 Old 05-20-2007, 09:55 PM
NautikaL's Avatar
Chris,
Are you talking about a real projector?
NautikaL is offline
Reply CRT Projectors
